Results 1 to 9 of 9
Thread: First pool....am I getting this right? :-) Overkill? Halp!
  1. Back To Top    #1
    StarSpun's Avatar
    Join Date
    Feb 2018
    Location
    Niagara Falls Canada (Summer) and Merritt Island Florida (winter)
    Posts
    6
    Red face First pool....am I getting this right? :-) Overkill? Halp!
    Hi all!
    We are waiting arrival of our first pool....a 16 x 8 with a 42 depth. I intend on using it with a harness to resistance train and do 'laps'. Also to float around in with a bevvie!
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    It's on the smaller side but it fits perfectly where we want to have it.
    I got an overkill (I think?) sand filter and salt water filtration. How much salt will I need to buy with this system?
    Sand filter:
    Salt System:
    I also got this sand for it....will this be enough?
    I heard I needed this adaptor for the above system, is this correct?
    Also got this heater, I'm thinking it may work ok with a smaller pool like this, what do you think? We are in Florida.
    Also going to buy this and cut it, for additional heat....
    Amazon.com : Thermo-Tex 12 Outdoor
    As for cleaning and such, I got the following. Is there anything else I need?
    Cleaning set:
    Skimmer:
    Vac:
    The harness I got for it in case anyone was wondering:
    As for the bottom of the pool, I've heard so many different ways to do it. So far I've only bought this elephant pad:
    What kind of foam do I need to put under this? Or does it go on top of the Elephant pad? Any links to something at Home Depot, etc? Should I use the tarp that comes with the pool as well or will it just come apart? We are in Florida and the pool will be staying put....
    Any links to a better tarp would be great
    We plan on putting paved stone around the pool, and also pave squares for the legs....is that good?
    I'm going to tiki this thing out! Bamboo and reed ready to go!
    SO EXCITED!
    Anything else you think we need to get this going, please let me know! Thanks so much! I can't wait!
    Photos to come as things progress!
  2. Back To Top    #2
    StarSpun's Avatar
    Join Date
    Feb 2018
    Location
    Posts
    6
    Re: First pool....am I getting this right? :-) Overkill? Halp!
    Here are some photos of the dig! As you can see, my chickens were helping, my hubby was not. He was lounging....too hungover from the festivities the day before....it was the launch in Cape Canaveral and we partied hard on a boat! Thankfully, I don't get hungover....I just go full steam the next day. Boy do my arms hurt now! What a pain to get things level!
  3. Back To Top    #3
    Mod Squad mknauss's Avatar
    Join Date
    May 2014
    Location
    Laughlin, NV
    Posts
    7,346
    Welcome to the forum!
    Every time I have been to Niagara Falls I have not seen palm trees ---------
    Can you put the location of the planned pool in your Member profile?
    Also a signature with your planned components, etc. See Pool School - Getting Started
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 w/SpeedStir! CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
  4. Back To Top    #4
    StarSpun's Avatar
    Join Date
    Feb 2018
    Location
    Posts
    6
    Quote Originally Posted by mknauss View Post
    Take care.
    Sure, will do as soon as I get home!
    We are snowbirds, Niagara Falls Canada in the summer, and Merritt Island Florida in the winter
  5. Back To Top    #5
    StarSpun's Avatar
    Join Date
    Feb 2018
    Location
    Posts
    6
    Ok fixed my signature
    Any thoughts on what to put under this? So many conflicting views. Any suggestions/knowledge would be so appreciated!
    Intex 16ft X 8ft X 42in Prism Frame Rectangular Above Ground Pool (3360 Gallons), Intex Krystal Clear Sand Filter Pump,Intex Krystal Clear Saltwater System with E.C.O. (Electrocatalytic Oxidation) for up to 15000-Gallon, GAME 4714 SolarPRO Contour Solar Pool Heater for Intex, Intex Deluxe Wall Mount Surface Skimmer, Intex Auto Pool Cleaner
  6. Back To Top    #6
    CJadamec's Avatar
    Join Date
    Apr 2016
    Location
    Quaker Hill, CT
    Posts
    2,069
    Looks like you have a great start to a new pool. Don't forget the solid concrete blocks for under the frame uprights. Get the 4 inch thick ones they cost less than $2 each at your local home improvement store. You need one block for every upright.
    The one thing I would take off your list is that solar heater. Those style heaters really don't work all that well. They just aren't big enough to provide meaningful heat for the pool. If you can find a place to put it get something like https://www.amazon.com/gp/aw/d/B00IU...ID=61EBH9fzaoL
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
  7. Back To Top    #7
    StarSpun's Avatar
    Join Date
    Feb 2018
    Location
    Posts
    6
    Ahhh! Thanks CJadamec! I didn't know they had to be 4 inches. Perfect, we'll get those, thank you!
    Funny, I had that exact heat system you mentioned in my cart ready to go just in case this one doesn't work. I figured with a small pool in Florida, it would be enough, but if not, I'll go for this one!
    Thanks again, good to know we are on the right track....
    Pool arrives this Tuesday, and the Elephant pad on Wed, so we'll start the set up on Wed I guess. Going to home depot tomorrow and hoping someone will know what kind of foam to put down underneath.
    Quote Originally Posted by CJadamec View Post
  8. Back To Top    #8
    StarSpun's Avatar
    Join Date
    Feb 2018
    Location
    Posts
    6
    The pool is arriving any time now....we've laid down the foam and are waiting for the elephant liner. A bit nervous we are gonna screw it up somehow....haha!
    But can't wait to have my own pool Pictures to come!
  9. Back To Top    #9
    Join Date
    May 2017
    Location
    Groveton, Tx
    Posts
    48
    What foam did you get?
    16x32x52 Intex Ultra Frame submerged 3 feet in ground Intex sand filter & pump Krystal Klear Saltwater Generator
Posting Permissions
  • You may not post replies
  • You may not edit your posts
