Results 1 to 6 of 6
Thread: Lost Post
  1. Back To Top    #1
    Join Date
    Aug 2016
    Location
    Montreal, Quebec, Canada
    Posts
    27
    Lost Post
    Hello forum managers!
    Late last November (2017) I put up a post in the Salt Water Chlorine Generators (SWG) section.
    I was interested in designing a simple SWCG board, and control it with an Arduino microprocessor.
    I received one or two very interesting responses.
    For some reason this post has vanished.
    I would be very interested in being able to re-see those responses.
    Any chance this post can be salvaged?
    Thanks in advance!
    Ron
    Montreal
    Sundance Cameo portable Spa, 370 gallons, 101oF, cover on when tub not in use, Taylor K-2006 test kit;
    FC: 2-5 ppm; CC: < 0.5 ppm; pH: 7.6; TA: 45ppm; CH: 125ppm; Borates: 50ppm;
  2. Back To Top    #2
    Mod Squad kimkats's Avatar
    Join Date
    Jul 2012
    Location
    Tallahassee, FL
    Posts
    31,544
    Re: Lost Post
    I went back and looked and do not see ANY posts from you in Nov. of 17. Your last post was 8/16/17 as seen here:
    Debris flowing back into pool
    I will tag this for our IT guy but don't think he will see anything different than what I did.
    Kim TFP MOD
    TFP Moderator 33x52 round AG 25,600 gals Sand Filter 1.5hp Pump - 2 Speed, SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math, Chlorine/CYA Chart, TF-100 Test Kit
  3. Back To Top    #3
    Mod Squad JohnT's Avatar
    Join Date
    Apr 2007
    Location
    SW Indiana
    Posts
    9,202
    Re: Lost Post
    Hi Ron,
    I've searched the depths of the forum and found no trace of such a post, even in the logs. No record of any post by you between this post and the 8/16 post Kim mentioned. I even looked under the couch cushions and in the junk drawer . We don't delete posts even in cases of rule violations, so it would have been somewhere.
    I did however find a post you made on another site about that time: Logic diagram for hot tub control unit
    Hope that is useful.
    John
    TFP Moderator
    20K Gallon 20X36 Vinyl Inground
    Hayward S244T Sand Filter with 1HP Whisperflo Pump. Liquidator C-201 and Solar Heat
  4. Back To Top    #4
    Join Date
    Aug 2016
    Location
    Posts
    27
    Re: Lost Post
    OMG, now I'm embarrassed!
    Time to have my Alzheimer's meds adjusted.
    I sincerely apologize for my confusion!
    Thanks a million for guiding me to my original post!
    Ron
  5. Back To Top    #5
    Join Date
    Apr 2007
    Location
    SW Indiana
    Posts
    9,202
    Re: Lost Post
    Quote Originally Posted by presse55 View Post
    Ron
    Next time I lose my phone I'll need you to find it for me!
    TFP Moderator
  6. Back To Top    #6
    JoyfulNoise's Avatar
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    13,412
    Re: Lost Post
    You might want to read through this thread on the technical details of SWGs especially Post #16 -
    SWG - Amps Volts and bipolar cells
    Modern cells only energize one set of plates while the alternate set is allowed to “float”. This greatly simplifies the electrical design of the power supply.
    Also, be careful of the chemistry advice you got on that other forum, it’s totally wrong. SWGs product chlorine gas, not sodium hypochlorite. They also produce hydrogen gas. You have to be very careful of the design of the cell in order to ensure that gases cannot build up. Hydrogen/Chlorine gas mixtures are explosive and easily detonate. There are plenty of incidences in this forum and others where improperly installed and operated SWG cells have exploded.
    Matt
    16k IG PebbleTec pool, 650gal spa, spillway and waterfall, 3HP IntelliFlo VS / 1.5HP WhisperFlo, Pentair QuadDE-100 filter, IC40 SWCG, MasterTemp 400k BTU/hr NG heater, KreepyKrauly suction-side cleaner Dolphin S300i robot, EasyTouch controls, city water, K-1001, K-2006 and K-1766 test kits, Mannitol test for borates
Posting Permissions
  • You may not post replies
  • You may not edit your posts
