Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: New Pool has started! Raleigh NC
  1. Back To Top    #1
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    21
    Our pool builder has started the construction!
    I'm also shopping for a heat pump with chiller.. Anybody have good/bad things to say about the Aquacal SQ120R? My builder will plumb/wire it up for me.
    Here's some eye candy.
    Pool Size: 35’ x 26’ x 15’ x 8’Perimeter ft. = 104 Surface area = 557sq. ft. -- Trapezoid shape w/tanning ledge and water feature--Depth ~ 3.5’ - 5’ - 4’deep
    Jandy 2.7 Horsepower VSE Stealth pump -- Jandy CV340 Cartridge Filter -- Aqua Pure Salt System
  2. Back To Top    #2
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    21
  3. Back To Top    #3
    bmoreswim's Avatar
    Join Date
    Jul 2012
    Location
    Central MD
    Posts
    3,817
    Re: New Pool has started! Raleigh NC
    Looks really pretty! Are those Leyland Cypress or a kind of juniper? How far are the trunks from the pool?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
  4. Back To Top    #4
    Mod Squad YippeeSkippy's Avatar
    Join Date
    Jan 2012
    Location
    'burbs of Augusta, Georgia
    Posts
    7,338
    What a wonderfully cleaver pool design for your space limitations! I love it... looks almost like a piano. Your little white pool inspector is precious too
    Keep the pictures coming, please!
    Maddie
    Maddie :) 12K Fiberglass IG, Infinity 4000 automatic cover, SWCG, Hayward Sand Filter, Hayward 1.5 Pump, Doheny Discovery Robot, Savi Melody LED pool lights, outdoor speakers and other assorted doo-dads. Sundance Altamar Hot Tub.
    Our pool build--> Our Pool Solved Our Sloping Yard Skippy's Cheap Pool Cooler -->Skippy's New Fountain
  5. Back To Top    #5
    ChuckDavis's Avatar
    Join Date
    Aug 2010
    Location
    Durham, NC
    Posts
    77
    Very clever use of limited space. For the narrow landscape strip, check out Steeplechase Arborvitae. Much narrower and bushier than Green Giant. I can give you information on where/how to special order if needed.
    15,000 gallon IGP, epoxy surface, waterfall, borates (!), not closed in winter
    SuperPump with 2.4 THP EcoTech variable speed motor, Tagelus TA-60 filter with zeolite media, Liquidator, AquaComfort heat pump, Blue-White flowmeter, Smartpool Wall Climber
    TF-100, LaMotte metal sequestrant test kits
    Sundance Capri hot tub
  6. Back To Top    #6
    bmoreswim's Avatar
    Join Date
    Jul 2012
    Location
    Central MD
    Posts
    3,817
    Quote Originally Posted by ChuckDavis View Post
    Looking at the first pic (link) in post #2, the evergreens are already in place and sure look like Leyland's. Ours are about 30' wide (not right at the base) and 40' tall after 17' years, starting at 2'. They can also blow their internal coat in very windy conditions starting after 10-15 years. During a strong wind storm a few years ago during the summer, our pool was 100% covered. Thankfully it floats and I was home.
  7. Back To Top    #7
    Mod Squad kimkats's Avatar
    Join Date
    Jul 2012
    Location
    Tallahassee, FL
    Posts
    30,476
    Purrfect for you yard! So well done! Did you or the PB come up with that design?? LOVE IT!
    Cute snoopavisor!
    To embed the pics in your posts you can use the img code. That way everyone can see them at a glance.
    You "job" right now is to measure the pool. Add about 8" for steel, gunite, and plaster. When will they do the steel?
    Kim
    TFP Moderator 33x52 round AG 25,600 gals Sand Filter 1.5hp Pump - 2 Speed, SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math, Chlorine/CYA Chart, TF-100 Test Kit
  8. Back To Top    #8
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    21
    For some reason the google photos don’t work inside the img tags here.
    Steel is done!
    https://photos.app.goo.gl/PXbW4YyYGddKtsPS2
    https://photos.app.goo.gl/TqtpGEKC3xmpKxAJ2
  9. Back To Top    #9
    Join Date
    Jul 2012
    Location
    Tallahassee, FL
    Posts
    30,476
    I see some pipe work as well!! Moving right along! When is the gunite?
    Kim
  10. Back To Top    #10
    riley00dog's Avatar
    Join Date
    Nov 2017
    Location
    Brisbane, Qld, Australia
    Posts
    1,094
    Love your design! It really does make great use of your space.
    3.2 x 6m | inground concrete | ~27,000 litre | 1.2 - 1.8m | salt and pepper mini pebble | SWCG Atral eq35| Viron xt 1.5 HP VS pump | Astral CA280 sand filter | DB3 robot | 2 x LED lights | travertine coping and paving | ceramic waterline tile |
  11. Back To Top    #11
    Join Date
    Feb 2018
    Location
    Raleigh NC
    Posts
    2
    Hi. Nice pool. I live in Wake Forest. Who is your PB? We are planning on a fall build and beginning to vet PB’s.
    Thanks!
    MOD note: Please PM the builders name. THANKS! Kim
  12. Back To Top    #12
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    21
    Quote Originally Posted by kimkats View Post
    Kim
    Scheduled for this Wednesday! Fingers crossed.
  13. Back To Top    #13
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    21
    Quote Originally Posted by bmoreswim View Post
    The trees are Spartan Junipers. They should be close to full size now - research says full size is 15-20 ft and 5 ft wide.
    Any concerns with their root structure breaking into the pool? Should I have some steel sheets put on the pool side?
  14. Back To Top    #14
    bmoreswim's Avatar
    Join Date
    Jul 2012
    Location
    Central MD
    Posts
    3,817
    I wouldn’t be concerned about the roots. However things don’t just stop growing. They will continue to get larger. Sizes listed are typically 10-15 year sizes. At which point most people have moved. But I am certainly glad to hear they aren’t Leyland’s in the narrow area.
  15. Back To Top    #15
    Sunnymosmile's Avatar
    Join Date
    Oct 2016
    Location
    Raleigh, NC
    Posts
    136
    Congrats! I’m in Raleigh too! I look forward to watching your build!
    16k Gallon, IG Vinyl, 16 x 34 x 25 Lagoon. Pentair Intelliflo VS2, ScreenLogic 2, Pentair Sand Filter, Colorlogic LEDs, TF-100, Speedstir, Pentair 920 Prowler (Rosie), and all wine is fine.
  16. Back To Top    #16
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    21
    Shooting the pool today!
  17. Back To Top    #17
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    21
    All done!
    My PB said not to hose the pool at all - any ideas why that might be?
  18. Back To Top    #18
    Join Date
    Jul 2012
    Location
    Tallahassee, FL
    Posts
    30,476
    No real idea but it may be due to your lower temps. The HOT of TX, AZ, CA, and Fl would mean you REALLY need to water. Up in NC I think it is cool enough you will not really need to at this time of year.
    NOW! It is time for YOUR own set of links!!!!
    Print these out:
    Bookmark these:
    PoolMath
    Make sure to ask any and all questions you might have no matter how small! We have all been where you are at one point.
    Ask your PB what test kit he will be providing you and let us know so we can fill in any holes.
    Kim
  19. Back To Top    #19
    riley00dog's Avatar
    Join Date
    Nov 2017
    Location
    Posts
    1,094
    Woo hoo! Looks great! Waiting for our concrete to be shot as I type. I'd say with low temps watering isn't necessary. Here we are in a heat wave in Brisbane, Australia so I'll be watering frequently.
  20. Back To Top    #20
    Join Date
    Mar 2007
    Location
    Raleigh, NC
    Posts
    21
    Print these out:
    Bookmark these:
    PoolMath
    Kim
    Thanks!!!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
