My first winter with an IGP. Had pool pump running 24/7 for entire season with perfectly balanced water until temps dropped dangerously low around New Years. Day and night temps were 0-4F and water was rapidly freezing despite pump running. Even had tarp over equipment pad with 60W bulbs.
Needless to say, had PB drain equipment and clear pipes in very cold weather as a precaution. Though water was too frozen to drain. Once it thawed I was able to pump out water down just below the tile line and remove skimmer baskets. Still water in the skimmers themselves.
Have opted to keep it “winterized” as the weather has been unseasonably warm/cold and don’t want to risk re-opening only to have another freeze spell.
Am so disappointed as I had immaculate chemistry and crystal clear water.
I’ve not been able to test water chemistry since pool surface has been frozen solid. Now that it’s thawed, should I still be checking chemistry and adding liquid chlorine or acid though pump no longer running?
