Results 1 to 3 of 3
Thread: Construction starting late March-Columbus, OH
  1. Back To Top    #1
    Join Date
    Feb 2017
    Location
    Canal Winchester, OH
    Posts
    15
    Hello all! I've enjoyed lurking here since we decided to "take the plunge." Plans are not anywhere near final, but it looks like construction may start late March. I'd love to hear some input based on your collective experiences on topics like pool covers, cleaners, and other equipment that we may need for our climate.
    Thanks in advance!
    Randy
  2. Back To Top    #2
    Mod Squad Jimrahbe's Avatar
    Join Date
    Jul 2014
    Location
    Bedford, TX
    Posts
    9,709
    Re: Construction starting late March-Columbus, OH
    Randy,
    Welcome to TFP... a great place to find the answers to all your new pool questions... no matter what "Canal" you live on...
    I am a highly biased Robot Pool Cleaner kind of guy. Water powered cleaners require you to run your pool pump, and sometimes two pumps, just to clean your pool. A Robot cleaner just needs an electrical outlet, and they do a much better job.
    Equipment wise, I would suggest a Variable speed or at least a 2-speed pump.. I would never install a single speed pump on a new pool...
    Now is the time to start thinking about how you plan to chlorinate your pool... There are four ways to chlorinate a pool...
    1. Use chlorinated 3" pucks... We do not recommend them for long term use.. Most of our members found this site while fighting green pools caused by continual puck use..
    2. Manually add Liquid Chlorine or plain Bleach on a regular basis. Usually daily or every other day.
    3. Use a Stenner pump to automatically add Liquid Chlorine or bleach.
    4. Use a Saltwater Chlorine Generator (SWCG) to convert the salt in your pool into chlorine.
    Thanks for posting,
    Jim R.
    Finished in 2015 - 17K Gal, IG, 20' x 25' Almost Rectangular Pool, Pebble finish, three rockport water falls. Pentair Equipment: EasyTouch 4, IC40 SWG, 3 HP VS Pump, CCP520 Cartridge Filter.
    TF100 with SpeedStir and SampleSizer, ColorQ Pro 7, Dolphin Premier Robot Cleaner, added Screen Logic 2, added small 3 person Caldera Spa.
  3. Back To Top    #3
    Mod Squad kimkats's Avatar
    Join Date
    Jul 2012
    Location
    Tallahassee, FL
    Posts
    34,760
    HI! I can't wait to help you spend your money! When you are ready you can start a thread here:
    Under Construction
    The best way to start is to show us where the pool will be going and what you want to do in the pool. Once we have that info we can start helping you plan you new pool!
    Kim
    TFP Moderator 33x52 round AG 25,600 gals Sand Filter 1.5hp Pump - 2 Speed, SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math, Chlorine/CYA Chart, TF-100 Test Kit
Posting Permissions
  • You may not post replies
  • You may not edit your posts
