Page 3 of 3 FirstFirst 123
Results 41 to 47 of 47
Thread: Stonescapes Aqua Blue finish turned black
  1. Back To Top    #41
    In the Industry
    PoolguyinCT's Avatar
    Join Date
    Jul 2014
    Location
    Connecticut
    Posts
    2,569
    Mis-bonds & stray currents with sequestering agents do some pretty wacky stuff, particularly when cl generation is involved.
    Iím going to check aqua mag, really just to see who wrote it.
  2. Back To Top    #42
    Join Date
    Jul 2011
    Location
    Arizona & California
    Posts
    846
    Re: Stonescapes Aqua Blue finish turned black
    I just skimmed over all of the posts.
    Has there been any consideration that the problem is that the blue pigment has been bleached out by chlorine?
    Which then leaves the dark gray color as the dominate color?
  3. Back To Top    #43
    In the Industry
    Join Date
    Jul 2014
    Location
    Connecticut
    Posts
    2,569
    A cored coupon or a discrete chisel if skimmer throat is plaster would answer that.
    - but a post indicates it did not react to acid when a piece was removed from the pool.
  4. Back To Top    #44
    Join Date
    Jul 2011
    Location
    Posts
    846
    Post #35 says that a "scratch test turned up blue"- that seems to indicate that perhaps the non-affected blue underneath can be exposed. ???
    The acid treatment may not have removed enough material to exposed the non-bleached blue pigment. ???
    Here is a link to an WaterShapes article written by onBalance about color pigments. Pigments and Pools | Pools/Spas | Watershapes
  5. Back To Top    #45
    In the Industry
    Join Date
    Jul 2014
    Location
    Connecticut
    Posts
    2,569
    Iíve read that link many times. Btw- Iím actually a big fan.
  6. Back To Top    #46
    Join Date
    May 2017
    Location
    FRANKFORT, il
    Posts
    14
    I'm in contact with OnBalance Thank you!
  7. Back To Top    #47
    Join Date
    May 2017
    Location
    FRANKFORT, il
    Posts
    14
    Update:
    We have had several pool companies come out to test. there is no consensus on what has happened other than they've never seen this before. All tests performed sow nothing. The manufacturer says that a corrosive environment can turn their finish black. I have the pool chemistry records and nothing indicates corrosive.
    So at this point it sounds like an attorney is going to have to get involved.
    Thanks to everyone including OnBalance for their help in this situation. For now I am going to close this thread and start another. Has any Stonescapes Midnight Blue (yes we got the wrong finish) turned black?
Posting Permissions
  • You may not post replies
  • You may not edit your posts
