Results 1 to 7 of 7
Thread: Wedding cake II steps (is there enough circulation?)
    gonefishin's Avatar
    Joliet, Il.
    413
    Hi all. I was looking at the wedding cake II steps and wondered if there is enough circulation going behind the steps to keep algae growth to a minimum. I've read that opinions said the original wedding cake steps didn't have enough circulation for some, but wondered if they have redesigned that at all with their new (II) model?
    thanks,
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,132
    I hunted down some images of the WC II design. Looks like they took the ideas from some of us on the various forums and cut a few extra holes in the sides of the steps. Heck, we should patent some of the terrific ideas we bring together here!
    Many of us who have the Wedding Cake steps have cut 2" holes into the sides in various places. I've had no problem with algae behind the steps. They sit a good 2-3" away from the pool wall and there appears to be plenty of circulation. When I add bleach I always pour a little on one side or the other and then swish it back there with a brush.
    I do have some algae inside the front step where the weights are. Not much, but it is there. We move the steps once a month, remove the weights, and brush visible algae spots while the steps are in the water. My husband loves the whole snorkel-and-goggles thing
    Anna
    — AnnaK —
    12,000 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    gonefishin's Avatar
    Joliet, Il.
    413
    Thanks for the reply Anna. The "II" design does look like it's incorporated a number of good ideas into the design. I'll have to give it some thought if I want to replace my current steps. Now that we have a deck entry instead of an outside ladder entry, it looks like the wedding cake steps may work out better.
    thanks,
    dan
    33' Aqua-Leader AGP
    Aqua-Rite t-15 SWG
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    This is why we chose the Biltmore steps.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Aug 2008
    PE, Canada
    7
    Re: Wedding cake II steps (is there enough circulation?)
    What are y'all using for weights for you wedding cake steps? Sandbags?
    Pool Newbie
    14,500 GAL AG Vinyl Lomart
    15' x 30' Oval
    Hayward sand filter,1 hp pump
    AnnaK's Avatar
    Jul 2007
    1,132
    PVC tubes filled with sand and capped. Three placed in the cubby hole under the bottom step and three suspended inside from the top step. Here are some photos.
    I wanted to add something to the question about circulation. We bought a Wall Whale brush earlier this season, a nice tool which keeps the brush firmly on the bottom or sides rather than it drifting up. It produces a lot of water movement when you push it across the bottom of the pool and I often use it to mix in a bleach addition when the pump isn't running.
    I also use it to push water against the steps on both sides and the front. This method has done an excellent job circulating freshly bleached water behind the steps and has virtually eliminated algae growth. We had one tiny spot inside the bottom step this year, that's it.
    — AnnaK —
    Aug 2008
    PE, Canada
    7
    Quote Originally Posted by AnnaK
    What an awesome idea! Thanks, I am doing this tonight!
    Pool Newbie
    15' x 30' Oval
