Results 1 to 10 of 10
Thread: which is more accurate the poolmath website or the poolmath app?
    Apr 2015
    Saint Augustine Fl
    33
    I am entering my info in both and the results are different
    Which one is more accurate?
    Fresh Warer pool15k gallons
    Pentair Clean and Clear RP filter
    Pentair 320 chlorine filter
    1-1.5 Hp pump//TF-100 test kit
    May 2017
    Coventry, CT
    302
    Re: which is more accurate the poolmath website or the poolmath app?
    Can you give some example calculations? I've never seen any significant difference between the two.
    20' X 40' IG vinyl lined; 31,300 gallons; built ~30years ago
    Hayward 1HP Single Speed Pump w/Sand Filter
    Taylor K-2006,Rola-chem sodium hypo feeder/ 15 gallon tank
    Fill from soft/neutral well water, low flowrate well pump
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,280
    They’re both dead on......
    Please make sure your settings use the same pool size on both and make sure they’re both using the same unit of measurement (gallons, liters)
    Apr 2015
    Saint Augustine Fl
    33
    Pool volume
    14k
    Current chlo one 1
    Rise to 3
    Cya is 35
    App says add 37 oz
    Website says add 34oz
    Ph from 7.4 to 7 Ta 110
    App says 46 oz
    Website says add 43oz
    May 2017
    Coventry, CT
    302
    Quote Originally Posted by Fugazi View Post
    Pool volume
    14k
    Current chlo one 1
    Rise to 3
    Cya is 35
    App says add 37 oz
    Using 10.5 trade% bleach, I get 34oz, by volume, of bleach using both the app and the website
    Pool volume
    14k
    App says 46 oz
    I get 43oz, by volume, of 31.45%-20 Baume Muriatic Acid using both Pool Math Website AND the App
    Looks to me like your pool volume settings are different in the app and the website.
    domct203's Avatar
    Jun 2015
    CT
    3,753
    Pool volume
    14k
    Current chlo one 1
    Rise to 3
    Cya is 35
    App says add 37 oz
    App says 46 oz
    Are you using the PoolMath on this forum?
    When I do, I get the following to raise FC from 1ppm to 3ppm in a 14,000 gal pool:
    8.25% bleach = 41oz
    10% bleach = 36oz
    12.5% bleach = 29oz
    What strength bleach did you use to get 43oz?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Apr 2015
    Saint Augustine Fl
    33
    I am using pool math from this website and the iOS app from TFP
    22,647
    If I enter 14000 gallons in either I get 34 oz of 10.5% bleach to raise the FC by 2 ppm.
    If I enter 15000 gallons in either I get 37 oz of 10.5% bleach to raise the FC by 2 ppm.
    I just did that because I saw that your sig lists your pool size as 15k and you entered 14k in Poolmath.
    Apr 2015
    Saint Augustine Fl
    33
    Quote Originally Posted by Bama Rambler View Post
    Oops I forgot to change it on the website
    Doh
    Thanks
    Jun 2017
    Sachse, TX
    526
    Not clear why you would be targeting a pH of 7.0. Was that just for delta illustrative purposes?
    Blessings, Paul
    12K, StoneScapes Midnight Blue Mini Pebble w/abalone (July 2017 - executed bi-carb startup Refurb - Sachse, Tx), 3 shear descents on raised Austin stone beam, 2 sprayers, 2 skimmers, 4 returns, 2HP pump, STA-Rite S7M120 cartridge filter, 3/4HP Pump for Polaris 280, Circupool RJ 45+, TF-2006, K-1766, & SpeedStir
