Results 1 to 15 of 15
Thread: Old pool floor cleaning system
    Dec 2017
    Henderson
    6
    hello everyone
    I'm trying to fix my pool cleaning system (don't know the history about it since i bought the house a year ago) and i opened the valve just to find that is empty, no gears or nothing inside , and where the pop up heads are they replace them with a plastic cover just to allow the water flow. i think the system couldn't be cancel since these are the only returns to the pool. the thing is that I'm about to re plaster my pool and i think would be the perfect time to install new pop up heads, now my questions are:
    -can i fix my current valve and install new pop up heads even if they are a different brand? (i was trying to find my valve brand but i don't see it, I'll attach a picture)
    -or i need to replace everything , valve and heads?
    all i know is a top feed valve with 4 ports in the bottom and 4 cancelled pop up heads in the pool.
    thanks in advance.I'll really appreciate any suggestions
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,470
    Re: Old pool floor cleaning system
    IO75:
    Welcome to the forum and please add your signature. Where is Henderson? Please describe the pool in a little more detail. Do you have any skimmers? Main drains? You state that only 4 pop up heads/returns are in your pool (where are they located)? And you also state that your pool has no wall returns at all? Any cleaner lines? Also, if possible please take a picture of the equipment pad.
    Below is a thread that describes the system, but during the closing procedures that will help you gain insight. There are links that you can click on that shows parts, etc. May not be your system, but at least you will have an idea. If the PB only installed a floor system, you will have to fix it as this will be your primary source of circulation. Thank you.
    Paramount System - Plugs, etc.
    Safety cover and water levels
    Go to the township and see if they have records on who built your pool. Then you can go back to the pool builder (hopefully still in business) and inquire about the pool and the system and hopefully they will have some information for you. You will probably be able to fix the system, if not at least modify, upgrade, etc. This will probably have to be done by the same company that takes care of the plaster.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    1,741
    Please post photos of the floor system , entire filter system & any piping penetrations on pool walls. - that looks like an old “pool valet” housing. - & I recommend you pay for a pressure test to qualify all of the piping before plaster.
    sktn77a's Avatar
    Chapel Hill, NC
    285
    Never mind.
    Keith
    15,000 gallon in-ground gunite/plaster pool, 1.5" PVC plumbing
    1.0HP Sta-Rite DuraGlass P2R pump, Hayward S244T sand filter
    Teledyne-Laars Lite-2 250k heater, Hayward CL200 chlorinator
    Polaris 380/Hayward 6060 booster pump
    Jul 2014
    Connecticut
    1,741
    2nd thought - that looks more like a Jandy dome, now that I zoom on it.
    Apr 2015
    tucson, arizona
    1,221
    That's the old A&A Gould valve,AA Manufacturing Gould 5 Port T-Valve
    Jul 2014
    Connecticut
    1,741
    I’ve never heard of Gould.. I learn something everyday thnx!
    Dec 2017
    Henderson
    6
    Thanks for all the replies and sorry for the delay.
    yes, the pool has a skimmer, the main drain and the 4 pop up heads , no more returns on the wall for the pool. the spa has a drain and one return on the bottom and 6 in the upper part. I'll attach pictures.
    thanks
    (Henderson,Nevada)
    Catanzaro's Avatar
    Jul 2014
    2,470
    I am assuming that the pool has been up and running since you purchased the home. Under normal operation, do the 4 pop up heads lift up? If so, all at the same time and are they all working together? Are you purchasing a new unit (Gould 5 Port T-Valve), floor returns, etc?
    Considering you do not have wall returns and are going through a renovation, is it possible to add wall returns? This really all depends on your patio, how far the distance, etc. If the cost was not too much, I would get rid of the floor returns (cut them out) and install 4 wall returns. The cost may be too much, depending on other factors.
    Dec 2017
    Henderson
    6
    The pool has been running since i purchased the house . if you zoom at the pictures you'll see there are no pop up heads , i think they just replaced with a cover , i''l confirm this week when i drain the pool.
    that was one of my original questions if i need to buy everything the same brand is already installed or i can just buy a newer (different brand) valve and floor returns . since I'm re plastering it will be easy to remove and install new pop up heads and collars. and not sure if i can just buy a complete 4 port valve and remove the old one.
    Adding wall returns and cancelling these will be too expensive and I'd like to keep the system the way it is just renovate it. I've been checking the prices and there are newer systems than this Gould at the same price probably cheaper.
    Apr 2015
    tucson, arizona
    1,221
    Master Pools Turbo Nozzles, looks like you have the original turbo heads, you can remove them and replace with recessed heads. This way they will be flush with new plaster
    Dec 2017
    Henderson
    6
    you meant replace only the heads? will these fit in the actual body? or i need to replace heads and collar?
    thanks.
    Jul 2014
    Connecticut
    1,741
    Just throwing it out there - did you open the valve to see if the drive gear are installed?
    Apr 2015
    tucson, arizona
    1,221
    When you remove the old turbo heads you will need the adapter to accept the new heads. The link I sent has several brands
    Dec 2017
    Henderson
    6
    The valve is empty that's why i want to install a new one too. but it doesn't need to be the same Gould brand correct?
    can i use any of these complete kits?
    Caretaker 2" Complete pop up heads with collar and cap
    thanks.
