G'day all from down under.
First off, love all the good advice on here, I have spent many hours reading through all the amazing info and your help so far has been amazing.
Problem:
I have recently come across a 'No Flow' error on my SWG, I am getting about 13psi (90Kpa) pressure and since it has been installed in April, I have had no issues up until now.
According to the manual the 'No Flow' can be caused by The pump turned off/disconnected or valves closed OR Blue wire disconnected from cell
Attempted solutions:
I have checked the blue wire is connected. It is fasted by a wingnut and there is no corroding or wear on it at all.I noticed some build up on the sensor inside the unit and then cleaned it as per the manual 1:10 hydrochloric to water. I left it for a few minutes then rinsed it. The error persisted
I then left it for a day running as per normal hoping the error needed time to sort itself out. The error persisted
I gave it another clean as the manual suggests repeat if necessary and plugged it all back in. The error persisted
I appreciate your help! I don't live in a metro area so regular trips to the pool store are out of the question, this website has been amazing for helping me manage the pool.
Obligatory pool readings:
TA 120
PH 7.6
FC 4 (managing with liquid chlorine atm)
CC 0
CH 200
Salt 4000 (estimate, I added some more salt today as it was around 3500ppm)
Problem:
TA 120
PH 7.6
CC 0
CH 200
