Hello again everyone. Been using our new solar heater for our 15-foot above-ground pool and we love it! Actually took a swim a couple times last week . . . in November! The pool was a comfortable 82 degrees. However, now that it's getting a bit cooler here in central Florida, the solar heater is struggling to get to 80. The heater says the water on the roof is 117 degrees. But what is happening is the pool gets to 82 and then goes back down to 75. Up and down up and down. It never gets a chance to keep that heat inside.
So, I had an interesting idea. We have a solar blanket for the pool. How about something to go around the outside of the pool to keep the heat in? I really think that is where most of the heat loss is at night. When we get in, you can feel the coolness on the inside wall.
So that is when the argument began between me and my husband. He wants to see the numbers because he doesn't think it will do much to retain heat. I've seen a wrapping called "double bubble." It's for above-ground pools. It's bubbles on one side and reflective on the other. I'm sure there's other kinds of waterproof barriers that could be used. He's also worried that if it's not right up against the walls, it won't work. We have braces about every four or five feet. The barrier would have to conform to those somehow.
I guess what I'm interested in is if anyone has done this and been successful. I just want a couple of degrees since right now the pool temp is stuck between 78 and 79 in the afternoon. What do you guys think?
