Page 3 of 18 FirstFirst 12345613 ... LastLast
Results 41 to 60 of 342
Thread: Riverside, CA - Backyard Overhaul
  1. Back To Top    #41
    Mod Squad kimkats's Avatar
    Join Date
    Jul 2012
    Location
    Tallahassee, FL
    Posts
    27,782
    Re: Riverside, CA - Backyard Overhaul
    Funny how things work out. Very glad you were able to find a crew that do it for you.
    Now go measure everything to make sure it is correct lol like I need to tell you this
    Kim
    TFP Moderator 33x52 round AG 25,600 gals Sand Filter 1.5hp Pump - 2 Speed, SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math, Chlorine/CYA Chart, TF-100 Test Kit
  2. Back To Top    #42
    In the Industry
    bdavis466's Avatar
    Join Date
    Aug 2014
    Location
    Riverside, CA
    Posts
    3,503
    Quote Originally Posted by kimkats View Post
    Kim
    Ha! I probably should... I'm just winging this
    Barring the inspection passes, shotcrete is scheduled for Saturday
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
  3. Back To Top    #43
    JoyfulNoise's Avatar
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    12,210
    Quote Originally Posted by bdavis466 View Post
    It's not so much a weight thing because the entire structure is probably about 10lbs Sq ft shared on four posts but a shear issue due to the posts and columns having 10-12' of leverage on the footing. It wouldn't take much force to transfer down to the pool and crack the shell.... That would be a very bad day for everyone.
    Here you can see that a 100 pound load at the top of the post translates into nearly 1,000 pounds on the post anchor... not to mention all of the other factors at play.
    Attachment 70924
    But it’s not just the combined total load that matters. A bending moment like that puts the concrete in both tensile and compressive stress. Concrete is great in compression (that’s the often quoted “3000psi concrete” number) but lousy in tension. So you need a much larger “chunk” of concrete to absorb the additional bending forces.
    Buts that’s as far as I got in MechE before realizing I liked chemistry a whole lot better ... and calculating load points and bending moments on the purely theoretical “mass-less” truss drove me bonkers
    Matt
    16k IG PebbleTec pool, 650gal spa, spillway and waterfall, 3HP IntelliFlo VS / 1.5HP WhisperFlo, Pentair QuadDE-100 filter, IC40 SWCG, MasterTemp 400k BTU/hr NG heater, KreepyKrauly suction-side cleaner Dolphin S300i robot, EasyTouch controls, city water, K-1001, K-2006 and K-1766 test kits, Mannitol test for borates
  4. Back To Top    #44
    In the Industry
    bdavis466's Avatar
    Join Date
    Aug 2014
    Location
    Riverside, CA
    Posts
    3,503
    That's why the columns have to be 32" square minimum and completely solid shotcrete. I can't imagine what this would look like if it had to support some serious weight.
    Thanks for finally chiming in... Kim and I were getting lonely in here
    -Brian-
    POOL BUILD
  5. Back To Top    #45
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    12,210
    Having switched to the new theme, I’m currently missing a lot of new posts that I would normally add my unwanted & nonsensical commentary to....perhaps Lee designed it that way
    Details aside, this pool build is going to epic! Way to go out on a high note
    Matt
  6. Back To Top    #46
    In the Industry
    bdavis466's Avatar
    Join Date
    Aug 2014
    Location
    Riverside, CA
    Posts
    3,503
    More progress today. Wanger and I remove a window, replaced a window and turned a slider into a window all to make way for the patio cover. Of course new windows were 2" larger than the old ones
    Plumbing is just about wrapped up, the lumber delivery and visit from the inspector will be tomorrow.
    -Brian-
    POOL BUILD
  7. Back To Top    #47
    In the Industry
    bdavis466's Avatar
    Join Date
    Aug 2014
    Location
    Riverside, CA
    Posts
    3,503
    My uncle pulled through on those post anchors and here they are. I'll weld them into place tomorrow.
    -Brian-
    POOL BUILD
  8. Back To Top    #48
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    12,210
    You lay pipe well....
    I’ll just leave it at that.
    Matt
  9. Back To Top    #49
    In the Industry
    bdavis466's Avatar
    Join Date
    Aug 2014
    Location
    Riverside, CA
    Posts
    3,503
    Quote Originally Posted by JoyfulNoise View Post
    Just wait until you see the equipment pad....
    I'm hoping I get to be the first to try this seat in the spa out - tri jets for the back dual calve jets and a floor foot jet
    -Brian-
    POOL BUILD
  10. Back To Top    #50
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    12,210
    That is some serious plumbing!! Why two Hartford loops...two air lines?
    Matt
  11. Back To Top    #51
    In the Industry
    bdavis466's Avatar
    Join Date
    Aug 2014
    Location
    Riverside, CA
    Posts
    3,503
    I always split and loop the air line and do the same for the return jets. Pipe is cheap, unsatisfied customers.... Not so much
    -Brian-
    POOL BUILD
  12. Back To Top    #52
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    12,210
    Matt
  13. Back To Top    #53
    Join Date
    Jul 2012
    Location
    Tallahassee, FL
    Posts
    27,782
    So who is this Wanger? He looks like hard worker!
    Of course the windows were a different size You have been doing this long enough to know that is how it should be.............nothing is the same or easy!
    That spa is going to be neat!!!
    Kim
  14. Back To Top    #54
    In the Industry
    bdavis466's Avatar
    Join Date
    Aug 2014
    Location
    Riverside, CA
    Posts
    3,503
    I teach at the fire academy and he was one of the students to go through it a little while back. He heard I did construction and asked if I needed help....I had a remodel going that needed almost 2,000 SQ ft of concrete broken out with no access for a tractor so jackhammer only and haul it off in wheelbarrows.
    He never complained and asked when I needed him next. He's been around ever since.
    His days are numbered though because it looks like he's going to get hired by the fire department.
    I just learned not too long ago that his last name is actually Wenger...too late, it's Wanger now
    Here he is on that job:
    That hill was way stepper than it looked and about 300 feet from where the pool was
    -Brian-
    POOL BUILD
  15. Back To Top    #55
    Join Date
    Jul 2012
    Location
    Tallahassee, FL
    Posts
    27,782
    He sounds like the kind of people that gives you hope for the future! Hard working and coming back for more! I bet you are proud of him!
    Kim
  16. Back To Top    #56
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    12,210
    Hahahahaha...you should have just called him “chuck” ....
    Matt
  17. Back To Top    #57
    In the Industry
    bdavis466's Avatar
    Join Date
    Aug 2014
    Location
    Riverside, CA
    Posts
    3,503
    It's always been Wanger. I like the looks I get from people when I introduce him!
    This is Wanger.....
    -Brian-
    POOL BUILD
  18. Back To Top    #58
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    12,210
    This is Wanger.....
    It would be worse if you referred to him as “this is my wanger.”
    Can I borrow your Wanger, I have a demolition job for him...
    Matt
  19. Back To Top    #59
    In the Industry
    bdavis466's Avatar
    Join Date
    Aug 2014
    Location
    Riverside, CA
    Posts
    3,503
    I don't like letting my Wanger hang out with just anyone
    -Brian-
    POOL BUILD
  20. Back To Top    #60
    Join Date
    May 2015
    Location
    Tucson, AZ
    Posts
    12,210
    Oh sure, shows us your Wanger and then hide him away....you’re such a tease...
    Matt
Posting Permissions
  • You may not post replies
  • You may not edit your posts
