Thread: Water Level issue- Help!
    May 2017
    Purcellville
    10
    Help! We got a hard freeze randomly, down to 20 degrees when weeks before we were up in the 60s.
    So since we didn't close the pool all the way down we just ran the pump overnight like we have done in the prior year, well it looks like the seal from the pump to the DE filter popped (not sure why) and water was shooting out overnight and now my water level is like 2 inches above the shallow end.
    We have officially closed the pool, lines blown, antifreeze, cover all that good stuff, but my water line is still 2 inches in the shallow end.
    I have a hose line running to the pool to fill it but it could take a while.
    Is there anything else I should be doing? we are supposed to get down to 31 tonight and I'm concerned that my water level is too low.
    Am I worrying for no reason?
    16x36 vinyl pool (approx 1980's?), 8ft deep end approx 26k gallons, Hayward Pump, Hayward DE filter, Taylor K-2005. House bought in Aug -2016 discovered one return jet broken, and main drain not functional, does have one working return and one working skimmer.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,537
    Re: Water Level issue- Help!
    If you have another hose, you might be able to get two hoses running which will speed things up, but yep it sounds like you're doing the right things.
    Sounds like your main drain must be working!
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
