Given that you travel a lot, and you're probably spending $500 a year on chems right now... if it was mine, I would be justifying a bundle like the one I'll paste below. It often goes on sale for a fair bit less than the $2150 shown. It will supply all your chlorine for probably the next 8 or 10 years, especially if you're using TFPC from this point forward. You can install yourself if you're keen to do that, or probably get it all hooked up for $300 or $400. You'd just have to make sure a couple of your existing valves are compatible with the supplied actuators, but I bet they are. You could change the valves for not too much money if need be.
You'll then have control of chlorine feed for spa or pool, heat for spa or pool, control of the VS pump for solar, heating, and pop-ups, etc. When you're away, you can turn the SWG down a bit and put some pucks in the Rainbow, which will look after your pH, although will raise the CYA a bit, but with TFPC you can monitor, leave a little headroom, and manage that all just fine.
https://www.amazon.com/Pentair-521150-Automation-Intellichor-Transformer/dp/B008H9A0FQ
With water that cheap, I wouldn't hesitate to replace water, subject to managing draining risks, and get your CYA down to 80. If you want a better sense of where you're at now, don't trust the pool store number, believe me, you're better at testing! Do the diluted test described at item 8 of this link: Pool School - CYA and then you'll know what you're up against.
Using the diluted test I still come up with 3/8" below the 100 mark.
