Hi all! First time posting here, but I’ve gotten so much valuable information that I knew I could come here for advice.
We are fairly new pool owners - 17K gallon plaster pool was completed in May so we had a great Texas summer with it. Water chemistry seemed right on for the most part all summer - high PH but I’ve heard that is to be expected for awhile with new plaster. We used Muriatic Acid frequently to bring it down. I’ll admit that since we haven’t been swimming as much we’ve slacked off on weekly chemical checks so now we’re in a pickle.
Sunday chemical check with the Taylor Complete (FAS-DPD chlorine) kit:
FC - 7
PH - 7.6
Alkalinity - didn’t check ??*
CH - didn’t check ??*
CYA - off the chart, above 100 where the reading stops.
Observations I have (please correct me if any of this is wrong):
-We’d been using the 3” pucks, which I know now are not recommended as they raise the CYA. It was at the recommendation of the pool builder. We have an automatic puck feeder (if that’s a thing?). I have since taken all the pucks out.
-We’d been using liquid chlorine from Home Depot when we recorded low levels and then also shocking with Clorox Pool & Spa Xtra Blue powder shock about once a week. We have full sunlight, no trees, so it was eating up the chlorine pretty regularly. I’ve now read that you shouldn’t use that as it raises the CYA. Is that right?
Yesterday I backwashed and drained down past the skimmers, refilled with fresh water and added about 1/2 gallon of liquid chlorine (based on the chart that says high CYA needs high chlorine levels).
Checked levels today:
FC - 9.5
PH - 7.2 (why did it go down so low?)
Alkalinity - 100
CH - 400
CYA - right at 100, so it has come down a little.
Based on all this, here are my questions...
Can we just continue to slowly dilute to bring the CYA down? Water is clear and no visible algae yet.
Should I do something about the low PH?
Sorry this is long. I wanted to include as much information as possible to get the most accurate responses. Thanks in advance!
FC - 7
PH - 7.6
FC - 9.5
Alkalinity - 100
CH - 400
