I think the pump on my pool is overheating. After running for several hours it will shut itself off for about 10 - 20 minutes, run for another 30 or so, and repeat. Is this a valid assumption? If so, guessing it's time to replace it (the filter, salt cell, and pump basket have all been cleaned, PSI is normal). The pump is about 11-12 years old (assuming it's the original, I just moved in 6 mos ago).
Attached is a photo of the current pump. I'm not sure where to begin with shopping for a new pump. I have heard that variable speed pumps are more energy efficient, but don't know much other than that. I see it's 1.5 HP, should I get another 1.5 HP, or is there a reason to consider going up/down in HP? Anything else important to be considered?
