Results 1 to 14 of 14
Thread: My Trouble Free Pool - Copper Sulfate
  1. Back To Top    #1
    Join Date
    Apr 2016
    Location
    Sunnyvale, CA
    Posts
    4
    I know this will go again the purists who say "all you need is Chlorine". Posting this just as my experience because it has been really life changing. First note my pool is not white but a mottled blue gray plaster and I don't care about appearance too much.
    I researched Copper sulfate 1.5 years ago. EPA considers small concentrations allowable for drinking water. I took my chances bought some on amazon for $20, and some Cu testing strips. I think you want to shoot for about 0.5-1ppm.
    A buddy of mine said I might kill my salt cell, because of electrolysis, but I had already done it.
    1.5 years later I'm happy to say:
    1) no stains I can see (but remember my pool is darker and mottled) - I think the secret here is don't keep adding the stuff - get it right and stop. It doesn't evaporate to my knowledge.
    2) no problem with the salt cell - in fact funtionning better than ever because my CYA is really under control because I have not had to shock the pool during that whole time except once (see item 3)
    3) No algae problems at all except once. I leave my pool unattended for weeks at time, I come back, everything is fine. The only time I had an issue was after the first spring, I had dumped a lot of rain water and not adjusted my CuSO4 back up. One algae bloom in a year and half. Got my Copper sulfate back up and no problem since then.
    So may not be for everyone, but for me, it has been absolute heaven and truly trouble free. I have not added Chlorine except for that one algae bloom. Usually with a salt cell, you don't need to, but realistically its hard to get it exactly right. I have had my Chlorine go very low and I was not punished for it, no algae.
    Again, just sharing in case this can help some people. Use at your own risk, don't go to high, read the posts about staining. You can do everything with Chlorine, but I found this much more forgiving.
    Paul Rousseau
    12.5K Gunite pool with blue gray plaster and 3M
    Pentair 1.5HP pump and Polaris 360
  2. Back To Top    #2
    Mod Squad YippeeSkippy's Avatar
    Join Date
    Jan 2012
    Location
    'burbs of Augusta, Georgia
    Posts
    8,080
    Re: My Trouble Free Pool - Copper Sulfate
    Paul, the biggest problem is your pool is not safe to swim in unless it is you and only you. Copper does not protect against bacteria or viral transmission, gastric woes from others, skin infections, eye infections are certainly all possible in your pool.
    And blonds can find their hair turning really, really green! Ooops!
    Copper works well as an algaecide but NOT against the other *cooties* I mention. Please reconsider your choices.
    Maddie
    ** If TFP has helped you and you want to return the favor...a most generous donor has challenged others on TFP to donate and they will match donations until the end of July up to $5,000!!! TFP is a 501(c)(3) charity. The website depends on your support to remain up and running, free of charge and help others learn how to manage and enjoy their pools the TFPC way!** Click here TFP July Challenge!!
  3. Back To Top    #3
    CJadamec's Avatar
    Join Date
    Apr 2016
    Location
    Quaker Hill, CT
    Posts
    2,171
    Actually he said he is using a SWG and has managed to track his CYA levels, not sure about his testing method tho.
    It sounds like he has used copper as an algecide and continued the SWG for sanitation. It also sounds like pool store testing and or lack of sufficient chlorine in the past do to high cya levels from magic pool store potions. Another possibility is that the SWG is too small for the pool and or starting to go bad.
    All the problems with copper aside in this case it is only masking the problem of inconsistent FC levels in the pool. Which as was pointed out is not a stay healthy while swimming.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
  4. Back To Top    #4
    domct203's Avatar
    Join Date
    Jun 2015
    Location
    CT
    Posts
    3,768
    I have a SWG, do not use copper or other algaecides, and do not get algae.
    Sure, I'll occasionally add some bleach for swim parties etc, but otherwise all I check is FC & CC daily, pH every 3-5 days, and the rest monthly. Adding copper would just be another thing to check and track, more trouble than it is worth to me.
    I am glad that the OP found a method that works for them to enjoy their pool, but it is not one that I would recommend. I get the same results with just one chemical (chlorine) and no metals.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
  5. Back To Top    #5
    In the Industry
    duraleigh's Avatar
    Join Date
    Apr 2007
    Location
    Sebring, Florida
    Posts
    30,706
    Nor will TFP ever suggest it, either. Copper is a complication that is not necessary to maintain a crystal clear pool.
    back in April, 2016, jblizzle suggested dropping the unnecessary stuff (here) but OP continues. That's fine and there is certainly more than one way to skin a cat.
    That said, the BEST way to skin the pool water cat is by following TFP guidelines. It's the simplest, usually the cheapest, and, oh yeah, it works perfectly!
    Dave S.
    42k vinyl and concrete pool, 1.5hp pump, 140gpm filter
    TFTestkits , PoolMath , Pool School
  6. Back To Top    #6
    In the Industry
    Donldson's Avatar
    Join Date
    Jun 2009
    Location
    NW Ohio
    Posts
    3,094
    Quote Originally Posted by prousseau View Post
    Now wait, why would you give advice that you specifically have to warn people could go horribly wrong? Why would you, after reading post after post after post on staining, possibly share that people should put themselves in a position to get such staining?
    Just FYI, if you ever have to preface your advice with "use at your own risk" then it probably doesn't belong on TFP. Given your 3 posts are all about using copper it is clear you have had a pretty set agenda from the beginning. You don't need to be some "chlorine purist" to recognize that your failure to maintain your pool and eagerness to find shortcuts does not leave you in a good position to offer anybody advice.
    But it is your pool and your call on what goes in it, I wish you the best of luck with it.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
  7. Back To Top    #7
    needsajet's Avatar
    Join Date
    Jan 2016
    Location
    Sydney, NSW, Australia
    Posts
    4,456
    One of the fundamentals of TFPC is that algae is used as the 'first sign of trouble'.
    If non-recommended chems are used to prevent algae, this 'algae alert' is likely to be lost from the system.
    When using TFPC, it's nearly impossible to have an accidentally unsanitary pool, because if algae is non-existent and FC is maintained per the FC/CYA chart, the pool is safe and sanitary - simple as that. So TFPC can't include copper as an algaecide because of sanitation risk, along with the likelihood of staining.
    While I don't agree, I found your explanation and reasoning easy to understand and respectful. I appreciated the detail you provided about your unique situation and tolerance for risk.
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
  8. Back To Top    #8
    Join Date
    Aug 2008
    Location
    Cle Elum, WA/Las Vegas, NV
    Posts
    11
    Why add another variable? KISS, Keep It Simple Student....
  9. Back To Top    #9
    Swampwoman's Avatar
    Join Date
    Apr 2012
    Location
    Grand Rapids, MI
    Posts
    3,818
    Paul, a dear friend of mine felt as you do about 20 years ago, and sure enough, he was algae-free.
    When I bought a house with a pool six years ago, before finding TFP, he was quick to tell me his bulletproof system.
    The next summer his wife's hair literally turned green. I ended up buying him a TFP kit and introducing him to a more precise method of pool care Not sure that it took. Her trip to the hairdressers cost a lot more than the kit, btw
    The long-term effect of that concentration misstep is still with them, whether its obvious to him or not. His wife no longer trusts the water and seriously is semi-adverse to swimming in her own pool, which, btw, she won't do without a bathing cap.
    That might sound minor in the larger scheme of things, and in terms of sanitation, it is. But the psychological impact of familial confidence in water quality should not be underestimated.
    When you say this:
    it makes me very nervous about a) your understanding of the behavior of copper and b) whether or not you actually test your ph levels much. Perhaps you control your ph tightly, which would explain how you're avoiding oxidization.
    But .5-1 ppm copper CAN and WILL stain and copper test strips are notoriously imprecise. Anything greater than .3 ppm is likely to stain and generally unforgiving.
    With a swg, and cya added deliberately to 70-80, and using the FC/CYA Chart chart, coincidentally, I've been algae-free since opening this pool - six years now. It's not only entirely possible to do this without copper - its preferable, because it (the levels, not just the absence of algae) means my water has been wholly sanitized and pathogen free for the duration. That's an important distinction to make because algae is sorta the canary in the coal mine in terms of FC.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    If TFP has helped you, please click to SUPPORT TFP!
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
  10. Back To Top    #10
    cubbybeave08's Avatar
    Join Date
    Feb 2008
    Location
    Northwest Indiana
    Posts
    902
    And Copper Sulfate is the stuff they put in sewer main lines to kill tree roots. Not sure, I'd put it in my pool at any concentration. Just saying.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
  11. Back To Top    #11
    domct203's Avatar
    Join Date
    Jun 2015
    Location
    CT
    Posts
    3,768
    Quote Originally Posted by cubbybeave08 View Post
    Reminds me of this thread.....
    Copper Sulfate usage???
    Dom - TFP Guide
  12. Back To Top    #12
    Join Date
    Oct 2014
    Location
    Bloomingdale
    Posts
    261
    I've learned from TFP over the last 6 years just how unnecessary copper sulfate, and Algecide really is...
    I personally wouldn't want it in my water.
    That said.....I was throwing around the idea a few years ago to build a ionizer with a small very low amp battery charger and a copper rod as an anode to put into my pool to prevent algae.
    Instead what I did is I took a few short pieces of electrical 12/2 romex wire, and tied it around the supports of my ladder.
    Has anyone ever tried the copper ionizer anode method here before just out of curiosity?
    Olympic brand pool and wide mouth skimmer. 7200 Gal. Vinyl liner. Hayward X Stream CCX 1500 1.5 hp. TPFC method. Triple filtration using Skimmer socks,10 micron Pleatco Cartridge Filter, Duda Diesel 5 Micron Bag. Kreepy Krawly Lil shark auto vacuum. Taylor K-2006 test kit with reagent refills. Pool School - Chlorine / CYA Chart
  13. Back To Top    #13
    domct203's Avatar
    Join Date
    Jun 2015
    Location
    CT
    Posts
    3,768
    Quote Originally Posted by RobertScalchi View Post
    You will still be putting copper into the water ......
    Dom - TFP Guide
  14. Back To Top    #14
    cfherrman's Avatar
    Join Date
    May 2017
    Location
    Hays, Kansas
    Posts
    1,645
    Preventing algae is a seriously bad idea, how do you know the water is safe? You can have a clear pool with insufficient FC to kill pathogens.
    Anything with copper is even a worse idea.
    Casey
    Intex 24' x 52" Filled to 40-45", 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
Posting Permissions
  • You may not post replies
  • You may not edit your posts
