Is this yellow algae or just regular type?
I'm just about to begin a slam/mustard slam as well...my first ever. When running the pump 24/7, what minimum speed is recommended? Also, is it better to backwash my filter before or after the procedure?
With a VS pump, you may run it slowly. 1000 RPM or so.
You should backwash your filter when your pressure rises 25% above clean pressure.
Take care.
No. But when the algae dies and is started to be filtered out, your pressure may rise fairly quickly. Depends on the algae outbreak.
Take care.
