Leak Question
Smack
Jul 27, 2009
2
Hi There, I am new to the forum and of course have a question...
I bought my parents house a few years ago and they have a 24 round 48" high above ground pool that is 11 years old. I've been watching it really closely and was convinced that we must have a hole in the liner. I called a local pool place and the guy game out and did a good look around the perimeter of the pool and he said he's not convinced that there is a hole.
I marked the water line and watched it over 4 days, it was half way up the skimmer when it started, and the past 2 days it was down to the bottom line of screws. It doesn't seem to go down past that, which makes me think there is a leak in the skimmer or that area. I had my husband look under the skimmer and he said there is a piece of wood under the connection and it is wet but it looks like it's just barely dripping.
So my question is, could that drip lead to a loss of 1" of water in 2 days. If so, any suggestions of how we could fix it?
the best way to tell if there's aleak is to do a bucket test.
Fill the pool to it's normal level. Take a 5 gallon bucket fill it about 2/3rd's full of water. Sit it on the top pool step and carefully mark the water level in the bucket then mark the water level of the pool water. Wait about 24 hours and see how much they've gone down. They should have both gone down the same amount. If the pool goes down more than the bucket you have a leak. Then the issue is finding it but sounds like you may have already.
Welcome to TFP!!
Give the inside and outside of the skimmer a good look - you'll see cracks in the body of the skimmer and water dripping if it's failed. Also look along the line from the skimmer to the pump for drips and ALL around the pump itself as well as the filter. You should see no water around the equipment - if you do see some, tell us where and we'll be able to point you in the direction of the leak :)
Thanks for the replies! I had my husband check underneath the skimmer yesterday and he said he was able to give the hose 3 or 4 good turns. We topped up the pool and continued to check for leaks, it seems like that did the trick. We were down about 1/8" (maybe even less) this morning but it was really hot yesterday so that didn't seem excessive, probably just splashing around and evaporation.
