Good evening to all...I’m new to the forum and hope some people give me some info.
First, I have a fiberglass (32x16) and it just had its 4th season. I noticed last year, and especially this year a white substance beginning to buildup on the steps, walls and floor. I’m pretty picky on keeping the water chemistry in check so never thought too much about it.
This past weekend I winterized the pool and drained some water to expose the steps and wow, was it white! I took a water sample to be tested and the results...TH-250, TC-3, FC-2, pH-7.1, TA-60, CyAcid-10. The water chemistry didnt seem too bad but I did raise my TA. I have city water (Del Co) and the pool was originally filled with it, and I use it to top off as I have an automated cover so it never gets filled with rain. I did a saturation index check last year and I was at -3.
I ran my fingernail over it and it will not come off. I know gel coat is permeable to water and my thinking is the dissolved minerals in the water have come out of solution and deposited under the gel coat. Del Co water has a history of being high in minerals and I think this is what I’m seeing...I hope??
Im thinking of trying Scale Tec Plus next year, maybe every 2 weeks and see if it changes. Has anyone seen or had this problem, and if so were you able to correct the problem? Any info would be greatly appreciated.
Tom
Tom
