I'm getting ready for my first closing, there are a few things I'm unsure of:
Thanks as always for helping to ease my mind!
- I believe my pool is marbelite, have heard this surface is meant to remain submerged. Do I need to raise the water level after closing or will safety cover run-off handle this over the closure period?
- Previous closing / opening was handled by same local pool co. They emptied my spillover spa and plugged the bottom drain then refilled. At opening they didn't remove the plug (it's still there). Should I close the spa the same way? Seems dumb to have to empty in the spring to remove plug & refill but I will if recommended.
- Is there such a thing as too much chlorine at closing? I have high CYA & persistent algae so was planning to add two extra 10L jugs of 12% just in case.
