My pump has started sucking extra air causing loss of suction and bubble blow into pool at water return. I have replaced gaskets and miracle greased connections. I have to vent air from the top of the sand filter each time I connect my suction pool cleaner, and the clear chamber before the pump that catches leaves no longer fills totally with water. Any ideas?
