Suggestions for a water-base silicone spray?
Ke
Sep 29, 2007
106
Toronto
My aquamatic motorized pool cover calls for using a water-based silicone spray for lubricating the sliders which run along the tracks, I am unable to find one that says it is water-based. the closest I could find is Jig-a-loo spray which says it is non oil-based. It seems to wash off quite easily from the fingers. Is this something I could use?
ya know what WD 40 is a Water based lube use that.I would never use this junk on any metal surface though it will just rust your junk up. On chains i use a chain wax or silicon spray like liquid wrench.
WD40 is NOT water based. The WD stands for 'water displacment' and it was the 40th formula developed. It is a petroleum based lube. It also does not contain silicone.
http://www.wd40.com/faqs/
LIQUID WRENCH also is petroleum based and does not contain silicone but they do make one that contains Teflon.
http://www.gunk.com/lubricants.asp
While your intentions were good your info was faulty.
ya WD-40 should never touch anything rubber / plastic / fiberglass in a pool. (Though it has a place in the tool box for sweaky filter tank nuts)
I LOVE silicone spay, I personally use a food grade silicone made by RDS. It lubricates very well. But it must be used with experience; since like all silicone sprays they will expand rubber. This is a nice tool but can be a curse if not used correctly. ... like spray your o-rings seconds before you assemble. ... if not.. they just may not fit by the time you get to it. ;-)
Once you use this stuff, you will never use a silicone "lube" like magic lube again.
Will it hold seal plate o-rings (Sta-Rite) in place during assembly?
