Hey everyone! I'm a little excited to share this as we bought the swim spa used from CL 2 years ago, and I'm finally able to say we spent our first few nights in it. It's so great I'm regretting not setting it up sooner! I've attached a link with some pictures for everyone's enjoyment;
1st Night
Spa is (not sure what brand....Haykeye I think, but they went out of business) 1800 gallons.
Now on to the technical stuff. I have this plumbed in to the same filter for the pool. I did this so I could disconnect the spa heater (5.5KW of electricity is too rich for my blood). This works flawless and the gas heater (400K Sta Rite) heated it from 65F to 99F in less than an hour! I have this tied in underneath so it does not effect the spa functions in any way. (2" "T" for supply, checkvalve, then "T" for return, all plumbed into a dual 2.5" drain under spa) I ran these lines up through an access I built into the slab before I poured concrete.
My question is this. I currently have a SWG and SW pool. I took water from the pool and dumped it into the spa (via valves at the pool pad).
Pool Pad (link);
Dropbox - Today
I don't think the low amount of salt (3000~3200ppm) will effect anything? Now I'm not entirely sure what to do about the chemistry. I've read the sticky at the top of this page, but wanted some suggestions from people with more experience. I really can't see using the SWG as a way to sanitize / chlorinate? I think it would add to much. Do most folks just test for the amount of sanitation needed and add bleach at the end of a soak? Another thing is my CYA is high for a hot tub (70 because of the pool), should I lower this to 30? (That would mean replacing with ~ 1026 gallons of fresh water!?!?!) I would really like to manage this with CYA of 70 if possible, because when it's time to do a water change, I'll just trade it out with the pool (No need to waste water).
Fwiw, some day I hope to have all this tuned with a Pentair Easy Touch, in which case I know I can set the "spa mode" to produce a much lower % of chlorine as per the SWG, which it would only produce when I turned it to "spa mode", ie when we're getting in or about to.
To sum it up;
1.) Is salt @ 3000ppm ok (I think so, and I've had no issues so far in a pool that was fresh water only)
2.) Can I manage it @ CYA 70
3.) Just test until I get a feel for how much bleach to add at the end of a soak and add it at the end of every soak?
Thanks all!
1st Night
Pool Pad (link);
Dropbox - Today
To sum it up;
Thanks all!
