Results 1 to 7 of 7
Thread: How Does Chlorine Safely React w/ Ammonia in a Pool?
    This is a bit off topic, but I am curious about this as mixing bleach and ammonia outside of water probably kills hundreds of people each year. How do they safely react within a pool? Is it just the levels of both are so low?
    11000 gallon Viking Fiberglass 12 x 28, Intellichlor IC-40 SWG, 24" cascade fountain, 12" cascade fountain, 1 1/2 HP pump, sand filter
    Mar 2007
    San Rafael, CA USA
    12,085
    Re: How Does Chlorine Safely React w/ Ammonia in a Pool?
    Yes, concentration is everything. The most irritating by-product in the reaction of chlorine with ammonia is nitrogen trichloride which is very volatile as well. The amount of nitrogen trichloride that is produced is proportional to the chlorine concentration, assuming there is an excess of chlorine relative to ammonia (which is usually the case). Technical details about this are here.
    The Cyanuric Acid (CYA) in pool water makes the effective active chlorine (hypochlorous acid) concentration very low -- roughly equivalent to around 0.1 ppm Free Chlorine (FC) if there were no CYA. So the amount of nitrogen trichloride produced under these conditions is exceptionally low. The concentration of 6% bleach is around 60,000 ppm or over 600,000 times higher. The concentration of ammonia in typical industrial or household accidents mixing chlorine with ammonia is also far higher than found in pools.
    Richard
    Aug 2009
    Northern CA
    29
    Quote Originally Posted by chem geek
    Great website!
    You guys are way ahead of the curve. You even leave most of the pool industry in the dust.
    I have a question that I have always wondered about and I think relates to this subject.
    I know of a few instances where bathers have developed rashes from using their spa. These were in ground pool/spa gunite swimming pools. The rashes always occurred in the spa, never in the pool. My theory is that large amounts of urea (in the confined area of the spa), converted the existing high levels of chlorine into monochloramine causing the irritation on the skin. Furthermore, since most spas are heated, the bather's skin pours are more open and susceptive.
    Could you elaborate on this a little bit more?
    Thanks!
    Mar 2007
    San Rafael, CA USA
    12,085
    Based on reports on spa forums I've seen, most rashes in spas are due to skin irritation from the jets or from people who have a skin condition that is sensitive to hot water. These rashes show up within 24 hours and get worse with additional exposure. Another source of rash is from the Pseudomonas aeruginosa bacteria, aka "hot tub rash/itch" though this usually shows up after 24 hours and doesn't get worse from additional exposure to the spa and is most commonly caused by too low a sanitizer level.
    It is, of course, possible for some people to be irritated by monochloramine and you are correct that in spas due to the high bather load (bathers per water volume) and high temperatures (so more sweat) that there is far higher exposure to monochloramine, but there is only anecdotal evidence of a small number of people affected (see this and this for differing viewpoints of monochloramine in tap water used for showering).
    Aug 2009
    Northern CA
    29
    Thanks for your take on the subject. I will have to add "jets" to my list. Of all the rashes I have personally known about, and after further investigation, urine was introduced into the spa.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Does this rash/itch-causing bacteria, or similar ones, also reside in swimming pools with normal santizer levels?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    It is extremely rare in swimming pools, it much prefers the warmer water in a spa.
