My MasterTemp 400 is cycling on and off. I checked for error codes but there were none. I checked the LED's on the back of the panel and when it cycled off the HLS LED was illuminated.
I changed the High Limit Switch as well as the Flue Stack Sensor (there was slight damage to one of the wires).
Now when I turn it on I have the same issue. I checked the stack temperature by holding down the pool on button. When the temp hits 260 it shuts off and the HLS illuminates. When the temp drops to below 160 the HLS LED goes out and the heater cycles back on.
Any help on what to check or do next?
