Like more than a few people, it seems, I'm tempted by the convenience of a SWG versus the whole "jugs of chlorine" routine. I'll be asking our pool guy for a quote on installation soon, but first I want to make sure I understand what I need/want.
Beyond the sig -- My sig says a ~22k pool and a 1.5hp single-speed pump. The 22k is a VERY rough estimate, as my pool's kidney shape and attached spa make the geometry tricky for this English major. I also don't know exact depths.
As for the pump, I'll be upgrading to a Pentair SuperFlo VS in a couple weeks as part of a set of home energy-efficiency upgrades.
SWG "size" -- My understanding is that I should aim for a SWG that's rated for roughly 2x my actual pool volume. This should allow for shorter daily run times and give proportionally longer cell life, as I understand it. Given the above, should I be looking at the IntelliChlor IC60? I'm not sure what my RPM schedule will be for the SuperFlo, but I'd like to run it at low speed as much as possible while still running it at higher RPMs enough for my pool cleaner (and SWG) to keep the pool clean. I assume that the RPM/GPM necessary to run the cleaner should also be sufficient flow for the SWG and vice versa.
Other equipment -- It sounds like it can use the intermatic timer that my pump is attached to? (That is, assuming the timer won't be needed for the pump once the upgrade to the SuperFlo is complete.)
What else is needed? Power supply and such?
Chemical costs -- Liquid chlorine costs should drop to zero, but acid will go up, it sounds like. Is it safe to assume that the increased acid costs won't be close to what my current chlorine costs are?
Maintenance -- Add salt every once in a while, keep a close eye on pH and CH, and replace the cell after a number of years. Is that it? Are there any types of failure that these units are prone to?
Thanks in advance for any help you can provide. I just started reading up today, and this has been a whole lot of info to try and take in at once....
