Went to the pool supply and had them test the water. They got a reading of 1600 for salinity, which just about matches the cell. My chlorine level is at 10 ppm according to their reading. I did the test before I went and it was 16 ppm. Added 2 bags of salt since the pool supply store recommended 3. Will see how that does. I remember the lid on the vacuum basket wasn't on tight. I'm thinking with that lid on loose and the vacuum being clogged with the pump running that maybe that caused the salt level to lower. Maybe it was sucking in air causing the basket not to stay fill with water.
Water bill is $15 higher then normal this month. Some of that could be from a few weeks ago when I had to add water because I noticed the water level was lower by about 6". I had to clean out the auto fill line and haven't had a problem since. Here's my water consumption for the last 4 months. May was when I replaced the water in the pool. Looks like my usage went up 3k gallons for August. Also doing the bucket test just to make sure there's not a leak.
08/01/17 10,498 7/21-8/22
07/01/17 7,165
06/01/17 6,900
05/01/17 15,588
3,354
Gallons
9/3/2017-9/9/2017
