Results 1 to 14 of 14
Thread: HAYWARD GAS HEATER
    HAYWARD GAS HEATER
    Hello all, looking for some help. I have a hayward h350 IDL2 gas heater. It is wired direct to fuse panel, no timer in between. Keeps blowing F2 fuse when i turn it on. Replaced fuse still blows. Replaced transformer still blows. Talked to hayward tech on phone,went through some tests with him and he said was transformer, bought new transformer installed and still blew same fuse. Im at wits end with this thing. Please help.
    Thanks greg
    Greg N.Y.
    15,000 gallon in ground, Polaris auto clear plus salt generator
    Vinyl liner, Hayward super pump
    DE filter, Hayward electronic gas heater H350IDL2
    Re: HAYWARD GAS HEATER
    First thought is, put a GFCI breaker within easy reach of the heater.
    No idea on the fuse issue. Is the unit clean, or are there objects in the wiring that could be creating continuity/short between connections?
    Wiring goes through house about 5 feet into panel with circuit protected breaker. No breaks or anything touching, it has been running fine for 2 months then all of a sudden this issue.
    Greg N.Y.
    Something in there's creating a load/short. Can't offer any advice beyond picking up a factory manual, and starting their debugging process.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    I'd start disconnecting components. Start with disconnecting the load side of the transformer and testing it by itself, then move on to the next.
    I TOOK OUT BOTH PRIMARY AND SECONDARY PINS TO THE FUSE BOARD. TURNED ON POWER TO UNIT, FUSE DIDNT BLOW. THEN I PLUGGED IN PRIMARY PIN FROM TRANSFORMER FUSE STILL DIDNT BLOW, WHEN I PLUGGED IN THE SECONDARY PIN THE FUSE BLEW, THAT IS WERE IM AT.
    THANK EVERYONE SO FAR FOR THE HELP ANY OTHER SUGGESTIONS?
    Greg N.Y.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    sure sounds like something is shorted in th secondary circuit. Anyone got a schematic?
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Could be something on the board, but you'll need to disconnect everything from the board except the transformer, then reconnect each component one at a time. Here's the diagram:[attachment=0:3puo89m4]H350 Wiring.JPG[/attachment:3puo89m4]
    Apr 2009
    Sarasota Florida
    143
    if it was the transformer i would have expected your breaker to trip. Where is that f2 fuse located? i do not see it on the diagram
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    TRY THIS DIAGRAM
    Greg N.Y.
    Sorry so big maybe this will help someone help me thanks
    Greg N.Y.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    It looks to me like you could pull p5 and p6 and isolate the board. If the fuse holds, plug them back in one at a time to see when the fuse blows.
    OK will try thanks ill get back to ya when it stops pouring here thanks
    Greg N.Y.
    Okay guys heater is fixed. It turned out to be a bad fuse board, had to replace for 165.00 bucks but all working fine. Thanks for all the help. Ordered part from swimmingpoolsetc.com lowest price out there on that part
    Greg
    Greg N.Y.
