Thread: Aqua Rite Generating Light
    My generating light comes on for a few seconds after starting and goes off. I assume that it is not generating.
    I tested the chlorine and TC is .3 and the Free C is 0. I am shocking the pool and algae is starting to be a problem.
    I took the cell to Leslie's for a test...it is good. I re-installed the cell and the generating light came on for a few seconds and went off.
    How can I trouble shoot this?
    Lonnie
    Re: Aqua Rite Generating Light
    Welcome to TFP!
    Try setting the percentage to 100% and see if it comes on then.
    Welcome to TFP!
    Thank you.
    It is set at 100% and the same - no generating light.
    Lonnie
    Jul 2007
    North of Dallas
    207
    what's your salt level at? use a strip to test it
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    Quote Originally Posted by sredish
    Salt is 3200 and CYA is 100.
    They have had a history of some bad circuit boards, ours did the same thing. Had the board replaced under warranty. It's the main board not the display board.
    22,000 Gallon inground gunite
    Pentair Intelliflo pump
    Pentair tr-100 sand filter
    Pentair Minimax NT 400,000 BTU heater
    AquaRite chlorine generator
    AquaPC-On Point chemical controller
