so as part of my search for a cause of DE leaking into my pool I noticed that my multiport valve is in a bit of bad shape. I looked at inyo and they says that my model is no longer available. Is it worth trying to fix this up or am i due for a replacement. What parts or replacement do you all recommend.
Symptoms:
Handle movement is very un-smooth (sounds crunchy).
Handle does not spring back into locked.
With pump off when I pull the handle back to move it I hear water flowing back towards the pull pump or return lines.
Water is leaking under the handle on the top of the unit.
Viewing bulb is no longer clear.
Has some small cracks possibly from time in the sun.
On a side note is seems like the waste line output port broke at some point and the previous owner stuck a PVC pipe in the middle with silicon. Guess that explains why it looks like a small water show when I backwash.
Pictures:
Valve:
Front view see pipe sticking out on left from break.
Cracked waste pipe.
-David
Symptoms:
Pictures:
Valve:
Cracked waste pipe.
-David
