Results 1 to 6 of 6
Thread: can you recommend a tool for this?
  1. Back To Top    #1
    Join Date
    Jul 2016
    Location
    Gainesville, FL
    Posts
    127
    there is a PVC fitting screwed to the bottom of my skimmer (see picture below). I am trying to remove it but it is impossible to hand-remove. there are hex sides at the bottom of it but I cannot think of a wrench or socket that will get in there around it. Some kind of T-shaped tool maybe?
    Inground 28000 gal Concrete, Hayward Progrid DE filter 6020, US motors 1.5hp pump (3450rpm) , Polaris 360
    600 gal hot tub, Spa Vita, Nature2+MPS
  2. Back To Top    #2
    Mr Bruce's Avatar
    Join Date
    Mar 2014
    Location
    Greenville, SC
    Posts
    2,091
    Re: can you recommend a tool for this?
    Do you care if you damage it? I would drop the water an inch below the top of the fitting and file or angle grind a slot in it and then use a screwdriver in the slot to turn it.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
  3. Back To Top    #3
    I'm guessing that it might be an mta. Maybe just push a piece of pipe into the socket and unscrew.
    Don't force it because it might be glued.
    Don't lean the pipe because it could crack the skimmer.
    Support the site
    Trouble Free Pool is a free resource. The people who answer questions are volunteers. If you find the site to be a good resource, please consider making a donation to help support the site. Thanks.
  4. Back To Top    #4
    TexasTraveler's Avatar
    Join Date
    May 2015
    Location
    Rockwall
    Posts
    5
    Probably late on this, but looks like a basin wrench is what you need... see example Milwaukee 2.5 in. Basin Wrench-48-22-7002 - The Home Depot
  5. Back To Top    #5
    aussieta's Avatar
    Join Date
    Jan 2014
    Location
    Langwarrin, Victoria, Australia
    Posts
    640
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
  6. Back To Top    #6
    kcindc's Avatar
    Join Date
    Sep 2011
    Location
    Fairfax, VA
    Posts
    1,282
    I wonder if a hot water heater wrench would work: Camco 5 in. Screw-In Element Wrench-09883 - The Home Depot
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
Posting Permissions
  • You may not post replies
  • You may not edit your posts
