The faster pH rise started with the addition of the SWG. Part of this pH rise may be from the increased aeration and part may be from chlorine outgassing. Is there a fairly short run of pipe from the SWG to the return(s) in the pool? You might try pointing your returns downwards (or diagonally down and to the side) to see if that gives the chlorine more time to dissolve into the water (if that's what is going on).
