Thread: 5ml vs 10ml for TF-100
    Jun 2017
    Chicago, IL
    81
    I purchased the TF-100 XL back in early July and after 2 slams I've already burned thru one bottle of the r-0871.
    I try to test FC once per day but find that my results are sometimes inconsistent so I end up retesting in the same sitting. As a result I'm using more of the r-0871.
    I've read that sometimes it is ok to use 5ml instead of 10ml. Is that correct? I tested tonight with 10ml and got 14FC, redid the test with 5ml and got 12FC
    I really want this kit to get me thru the summer. Any suggestions?
    Intex 15 x 48 AGP; vinyl liner; 5,300 gal; installed on 6/11/2017; Intex Filter Pump; TF-100.
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    4,759
    Re: 5ml vs 10ml for TF-100
    Why are you having to run your FC above 10?
    The 5 ml test is acceptable during a SLAM when the error rate is not as critical. At lower FC levels, you should use the 10ml protocol.
    With your FC at 10 or higher you can never test your pH.
    Take care.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflow 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
    Jun 2017
    Chicago, IL
    81
    My FC is still in the process of dropping from my recent slam. I like to leave it at about 8-9FC. I've found that I need it to be on the high side.
