Results 1 to 14 of 14
Thread: PSI up after adding DE
    Jan 2016
    Wichita, Kansas
    92
    I added 3/4 cup of DE to our sand filter today for the first time. The PSI started at 7 and went up one or two PSI after I added the last 1/4 cup, and now a couple hours later it's sitting at 14. I saw in the DE instructions that it could go up, but I'm wondering what do I do now that it has increased this much?
    AG Doughboy 16x28', Opened June 2016
    Aquaview 20" filter w 7 position valve
    1-1/2 hp Powerline Pump
    TF-100 Test Kit
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    3,873
    Re: PSI up after adding DE
    Back wash.
    6000 Gallon IG Fiberglass with integrated Spa
    Pentair CCP240 Cartridge Filter with Pentair Intelliflow 3050VS Pump and Pentair HTR250 heater. IC40 SWG. EasyTouch 4. TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Marty
    Jan 2016
    Wichita, Kansas
    92
    So then I lose the DE I just added?
    TF-100 Test Kit
    May 2014
    Laughlin, NV
    3,873
    Yes. When you add DE to a sand filter you are looking for a 1 psi or less rise. You added too much. Pool School - Add DE to a Sand Filter
    Marty
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    The DE you added did what DE does, it filtered out finer particles and in doing so raised the pressure. Backwash now and if you want to add DE, use less.
    chiefwej
    Jan 2016
    Wichita, Kansas
    92
    Ok, done. When I read "Add DE to a sand filter" I thought it said I would get close to two cups of DE before it was too much, so I guess I should have stopped at 1/4- 1/2 cup.
    TF-100 Test Kit
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,853
    The amount depends on the size of the sand filter.
    chiefwej
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,768
    Proof that adding DE works. How long would it take to see that pressure rise normally?
    Jan 2016
    Wichita, Kansas
    92
    It would normally take at least a week to go up that much. I added 1/4 cup yesterday and it handled it better. Still was up 2 psi by this morning so I backwashed again. I'm fighting an algae problem, and cloudiness, it did look a little better today. Been vacuuming and brushing every day for a week.
    TF-100 Test Kit
    May 2014
    Laughlin, NV
    3,873
    Algae is a chemistry problem, not a filtering problem. You most likely need to SLAM
    Take care.
    Marty
    Richard320's Avatar
    Jan 2010
    18,768
    Yep, what he said ^^^ You'll never get to the end of the algae unless you kill it all with the Shock Level And Maintain Process.
    Jan 2016
    Wichita, Kansas
    92
    Yeah, I just thought it might help with the cloudiness some. And I wanted to try the DE anyway.
    This is my first issue with algae. I've vacuumed and brushed every day for a week, I'll post test results, but they seem pretty stable to me. Every day when I vacuum, you can see a path where I've vacced and exactly where I haven't been. The first few days it looked like dust or some small particles billowing up on the pool bottom. Does this sound like algae?
    Do I need to slam?
    Yesterday's test results were :
    Chlorine 2.5
    PH 7.9
    CYA 30
    TA 60
    CC 0
    I adjusted with muriatic acid and chlorine
    TF-100 Test Kit
    May 2014
    Laughlin, NV
    3,873
    See Post #10. You have a chemistry problem, not a filtering problem. You need to SLAM
    Marty
    Jan 2016
    Wichita, Kansas
    92
    I brought chlorine levels up to 15 last night. Vaccumed again this morning, and it looks much better, cloudy still, but blue! I figured out that I was off on my chlorine, a few ounces short each day.
    TF-100 Test Kit
