Thread: Affect of cal-hypo and trichlor on levels
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    Is there a formula somewhere that indicates what the increase in calcium is per amount of cal-hypo and increase in CYA per amount of trichlor
    1lb of 73% cal-hypo for 21000 gallons of water = x calcium increase
    1lb of trichlor for 21000 gallons of water = x CYA increase
    21k gal, plaster IG pool with spa
    Main - 1 skimmer, 1 main drain, 3 returns, Spa - 1 drain, 4 returns
    WhisperFlo Dual Speed WFDS 1.5 HP pump
    S310S 30" sand filter
    Polaris 360 pressure cleaner
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Affect of cal-hypo and trichlor on levels
    Saw this posted by Chemgeek (Richard) earlier today:
    The following are chemical facts for some chlorine sources independent of concentration of product and of pool size:
    For every 10 ppm Free Chlorine (FC), Trichlor also increases Cyanuric Acid (CYA) by 6 ppm.
    For every 10 ppm FC, Dichlor also increases CYA by 9 ppm.
    For every 10 ppm FC, Cal-Hypo also increases Calcium Hardness (CH) by 7 ppm.
    You can use the effects of adding chemicals section of my Pool Calculator, towards the bottom, to answer questions like these.
