Thread: Solar Heater Controller using solenoid valve??
    Vero Beach, FL
    462
    I saw a controller that activates an irrigation style solenoid valve to close it and divert flow to the panels. Is there any advantage / disadvantage to this type of valve as opposed to the typical 3 way automatic valves?
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Re: Solar Heater Controller using solenoid valve??
    I'm not sure, but I've thought if using one of these myself. Only thing holding me back is the innability to find a 1.5" or 2" valve locally. Have you found one?
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Vero Beach, FL
    462
    Quote Originally Posted by launboy
    Adam
    Yes, I can get them locally at an irrigation store. Actually, it was several years ago that I saw them, but I don't know why they would not have them now. I've got 5 of them on irrigation system - all 1.5"
    Funny, yesterday I was thinking the same thing you wrote about in your other post. Getting a cheap digital thermostat, unsoldering the thermistor and embedding it in the rubber solar mat, then using that to control a solenoid valve. I'll be using the solar all winter, but just don't want the water going through the panels when it is cloudy and cold.
    Solar heat
