Hello all,
First off..this site is awesome and i'm glad to be a member.
This is my first post so here goes....
I just recently filled my pool about 4 weeks ago. My pool has a darker River Rok plaster(blue opal) and after 2 weeks, I started to notice some inconsistency in the color with some scattered patches of white appearing. My PB sent the plaster guys back and they did an "acid wash" to even out the color. This process took about 2 days (they turned off my pool equipment and had some sort of pump floating in the middle of my pool running 24-7). After it was completed, they turned on the fill line and started up the pump. The plaster guy told me to run the fill for another hour or so to dilute the acidity of whatever they used to even out the color. The plaster guy said it should be swim-ready in 2 days. Well 2 days later, using the test kit that the PB gave me with the pool, pH and TA was waaayy low; With this test kit, the alkalinity reagent starts out blue, then with a second reagent, you add drops one at a time until water turns yellow/white....the number of drops x 10 = ppm TA. My test water didn't even start blue with the first reagent! Knowing that really low pH can ruin pool equipment, I immediately decided to do something about raising the TA. I assumed a TA of 0 and using Pool Math and a target TA of 80, i calculated I needed about 23 pounds of baking soda. So in a span of about 5 hours I slowly added pre-dissolved baking soda(one 5-gallon bucket at a time) to my pool. Just to be on the safe side I only added about 13 pounds and retested TA to see if it changed. Well it did change and my TA is at roughly 25 ppm, but now my water is cloudy and can't even see my pool vacuum make its rounds.
I ordered the TF-100 so until i receive it, i'm unable to furnish a full set of test results, but I wanted some initial feedback from the pros here as to what could potentially be causing the problem.
