Hello,
I put up a 18x10x42 Oval pool last month. I converted it to the salt water system. The pool was doing great than the filter that came with the pool stopped working... I bought a new filter Krystal Clear 633T and connected everything. I even cut the hole bigger to make sure the nozzle fit. List of issues below.
1. when I cut the hole for the nozzle I screwed in the nozzle the new pump came with however there is a small drip of water on the outside wall. Can I get a washer for this or use plumbers glue to stop the leak?
2. After I started the pump and ran for 24 hours. I turned on the salt water system (eco 8110) and noticed after a short time that I am getting an error of 90 low filter flow. After reading the instructions and looking online is it possible that the hoses can be in the wrong direction? Should I change the hoses? I am a little scared to change the hoses b/c I don't want it to mess up my salt water system...
3. bought a skimmer for the pool and it's not working and it doesn't connect well to stand straight up to the inflatable side.... Any suggestions?
I am becoming discouraged with this and not sure where to go... I love the pool and I am wanting to get in it...
