Thread: TEST STRIPS
    TEST STRIPS
    Where can i order the Lamotte borate test strips?
    12K GL 16x25 IG VINYL , AUTOPILOT SWG , HAYWARD CARTRIDGE FILTER,
    1HP SUPERPUMP,HP2100TCO3T HEATPUMP
    SR SMITH TYPHOON SLIDE
    BORATES.TF100 TEST KIT
    Arizona
    925
    Re: TEST STRIPS
    You can order them at the same site that you ordered the TF100 test kit.
    http://www.tftestkits.net Then click on the Refills tab.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: TEST STRIPS
    www.intheswim.com also has them. probably some other places too.
    Re: TEST STRIPS
    Thanks . Didn't know they offered them also
