Page 1 of 4 1234 LastLast
Results 1 to 20 of 63
Thread: Completely Frustrated ANd going broke!!!!
    joseroman1014's Avatar
    Jul 2014
    Plainfield,NJ
    22
    Guys please explain to me the theory of what is going on here. So far I have with out exaggeration spent roughly 200.00 and roughly 40 bottles later I cant get this pool to hold any chlorine. Night before my reading were FC - 0, CC - .3, PH - 7.2, Total Alkalinity - 90, CA - 110, CYA 30. Using Taylor Test kit k2006c
    I add Bleach to Shock levels but it takes and extreme amount (3 Bottles of Bleach) and I got to shock levels after I tested halve hr. after addition. This morning There is 0 Free chlorine and CYA is 30. Go to get more bleach add it in to do the shock process one more time ( more like my 13th time) brought up to levels. I tested 3 hrs later before the sun went down and I can only get a reading of 1.6? Why Cant I get this pool balanced out. How much bleach to I need to add to this pool and how long has it taken some of you guys to get it right. Water is clear. Pool running all 24hrs.
    I did some research and added some D.E. as per the intructions on trouble free pool to see if this helps clear out any unseen algae?. I'm almost at the end of possibly being able to buy more bleach I'm going for broke here. Never had so much headache with my previous Salt Water System on my old setup.
    Any suggestions?
    Also how many on this forum are using periostaic pump systems in their pools to maintain Chlorine in their pools.
    Sharkline Escalade 24 x 52 aboveground Oval pool with 20 Mil overlap Liner
    15200 Gallons (According To Pool Math)
    17" Doughboy Aquaview Sand Filter with Doughboy 1.5hp Powerline XP1.
    Using D.E. in Sand Filter. Widemouth Skimmer. Taylor Water testing Kit K-2006C
    Pool Rover. Primary Source of Chlorine - Clorox Bleach.
    Re: Completely Frustrated ANd going broke!!!!
    How much Chlorine do you loose if you do an overnight test? Night to morning with no sunlight on the pool? That will tell you if something is eating up the chlorine other than sunlight
    Dennis in Central Indiana
    Pool owner for 4 seasons. 18 x 52 (7000 gallons) Intex Metal Frame pool. Hayward S210T93S Sand Filter and Pump (1 1/2 HP) w/ in wall skimmer. Taylor K2006 test kit w/speed stir.
    What is TFPC? Pool School Chlorine/CYA Chart Pool Math Recommended Test Kits
    DrHorshenschwartz's Avatar
    Jul 2017
    Throop, PA
    113
    Quote Originally Posted by joseroman1014 View Post
    Any suggestions?
    I think everyone will agree we need to know more. Pool type, gallons, history, what bleach specifically are you using ( a picture of the label would be good) is there organic material in the pool, are the testing agents in the kit fresh enough.
    15k gal, Above Ground vinyl, Generic Pump 83gpm HP: 1.5 SPL SF: 1.0 , No water features, 1.5" Hard PVC piping, Generic Sand Filter, Installed July 2016, City Water no Restrictions, Taylor K2006, Aquacheck 7-way Strips, Aquacheck Borate Test Strips.
    37,422
    And need know the CC level ... 0.3 is not a possible number.
    Jul 2014
    Plainfield,NJ
    22
    Quote Originally Posted by DrHorshenschwartz View Post
    Pool is a Vinyl Above Ground 24 x 52 with 15200 gallons of water according to the Calculations on Pool Math. I thought it was 15400. Its a new setup. Only set up about a 2 month Now. I came from an Intex 20 X 42 Steel Frame pool with a Salt Water Generator. The Bleach I'm using is Plain CLOROX from Home depot. (Cheapest Price So far) As far as the Agents ill check for Dates? Do they have any under the bottle? As far as Organics pool is kept clean by my Rover and the water is Clear. Ill take a Picture of the Clorox Bottom.
    For a clear indication of organics you should do an overnight FC loss test. It will tell us if there is organic matter in there consuming chlorine.
    Jul 2017
    Throop, PA
    113
    I'm not familiar with any of the cleaning robots so excuse me if I don't understand correctly when I ask if there's any chance there is organic matter in the robot or is the robot causing you to lose water or anything.
    I have essentially the same pool. 24 round by 52" deep. I just drained almost all the water and refilled Saturday. I'm in the process of uploading a video to YouTube under my name Cody Taber. The video shows a full round of testing with K-2006 kit as I know how. It'll probably be over an hour before it's done uploading and processing. I have a bunch of other videos uploaded that I need to put in order and shuffle around. Disregard those.
    The audio may even be too low.
    Not sure if mentioning my videos is allowed here. Sorry if it's not.
    I too went with 15200 and have only added three gallons since testing, four pounds of dry stabilizer, small amount of muriatic acid (make sure it's pure, not green) and four pounds of baking soda.
    So far so good.
    I'll review your case again and see what I can add.
    Jul 2017
    Throop, PA
    113
    Expiration dates should be on bottles.
    Is it possible your bleach is old. I buy from a grocery store which has big turnover.
    Home Depot may not have a big turn over or may be stored in the sun or maybe you have yours in the sun? I don't know how long it survives in the bottle in the sun.
    Any water loss?
    I prefer to start with everything out of the pool. I took the molded plastic stairs out and removed the vacuum hose from floating in the pool. I'd remove the robot too.
    Jul 2014
    Plainfield,NJ
    22
    Any water loss?
    Sounds like a plan. I took The Pool Vacuum out the water. The Stairs are bolted in so that I cant do. While I was out there I took a new reading. these are my results
    FC - 3.5ppm
    CC - .5ppm
    PH - 7.2ppm
    CYA - 30? The bubble never really disappears but I get to 30 it is a bit hazy though.
    Pump is running 24hrs. Lets see what the morning Brings.
    37,422
    Not sure there is enough light to accurately do the CYA test right now. What you described would be something less than 30, maybe 20?
    Feb 2017
    Ohio
    208
    East coast has in parts getting a lot of rain, did u drain since startup? Sounds like not enough cya....
    Rick, Fiberglass.....14 x 30 Viking Laguna - 10,000 gal. Pentair cartridge filter, gas heater, Swg, variable speed pump, Easytouch control system.
    k2006c, k1766
    Jul 2017
    Throop, PA
    113
    I agree with the other person replying. Not enough CYA. Did you ever add any?
    When we first got our pool just over a year ago I didn't understand the importance if CYA or stabilizer as it's called on the shelf. I had the same issue; put bleach in, test great, a couple hours later in July sun, no chlorine. Add more, burn money.
    I was following the BBB Method as described on YouTube by the guy who has the most popular pool channel. That Bleach, Baking Soda, Borax and I think he mentions Muriatic Acid but he never shows adding Cyuneric Acid and only very briefly mentioned stabilizer. I didn't know CYA was stabilizer at the time. And since he didn't add it either did I.
    So if the black dot is just a little cloudy at 30 which is the top of the test tube then I'd say you have zero.
    I purchased the four pound bottle of powdered stabilizer from Walmart and it was Clorox brand. I put it in a filter sock and hung it near the return jet yesterday. It saturated with water and seemed to not be dissolving much at all so I gave it a squeeze every now and then and it all finally ended up in the pool.
    The first time I filled the pool I just broadcast it over the water and it quickly sunk to the floor.
    Jun 2015
    Rocklin Ca
    78
    I haven't read every reply but just reading $200, 40 bottles of bleach, running the pump 24hrs. I had a problem with my pool not holding chlorine just to many trips to the pool store then I found TFP and started reading about slamming a pool how to take care of a pool. Then during that time a retired water engineer (assume he worked of a water agency) bought some CL stuff from me, his advice drain the pool and start over. So I drained about 2/3 of the water and started following TFP my pool never looked better cost is way down compared to pool stores. I've had to do a couple Slams or elevate the chlorine for a couple days after large parties but nothing drastic. So maybe you at that point and need a fresh start. Water cost average is $2 per 1000 gal. I also only buy chlorine from a local pool store, it's a higher percentage and always fresh.
    In ground 20,000gal - pebble-tec - salt, Intelliflo pump, Sta-Rite filter 450 sq ft ,Hayward 6060 booster pump, non functioning Aqua Rite SWCG, TF 100 test kit.
    Jun 2017
    Casa Grande, Arizona
    36
    OP said 3 gallons brings his pool to shock level. Now Im not sure what his shock level number is, but the calculator says 12. If his chlorine is getting it to shock level it must be of some strength. To educate the OP and myself, If the chlorine has lost some potency, does it get used up in the pool faster? That does not make sense to me. I can understand it taking more chlorine since it is weaker than new, but shouldn't it hold the same PPM unless there is something utilizing it? Does this make sense?
    Jul 2014
    Plainfield,NJ
    22
    Well guys these are my results from this morning test after last night add of Chlorine bleach.
    FC - 2.3
    CC - .4
    PH - 7.2
    CYA - again 30 - bubble doesn't even disappear. Slight haze
    Now this is what I found that has me intrigued. The Pool Bottom is super clean the walls don't feel slimy but I decided to jump on the ladder before stepping away for the day and I noticed something big time. There is a bunch of debris and algae collected behind the Stairs and under it. seems the pool cleaner cant get to it. Since the stairs are attached to the Rim of the pool and it had this Plastic Block for kids not to get under its all nasty under the there. I did lose some Chlorine (3.5ppm to 2.3ppm) and that was at 7AM this morning. Lets see what the summer sun brings. Probably back to zero by days end. As far as CYA, I'm going to try to increase this today and try to get it to at least 40 or 50 with some Clorox Stabilizer that ill pick up after. And ill get in this afternoon ad brush that whole area.
    Could this little patch of Green be eating all that chlorine?
    Second - I can get my hands on Concentrated Clorox Bleach. Is that the same or should I stick to the regular kind..
    Thanks again for all of you that have chimes in to help. I appreciate it.
    Apr 2016
    Riverview, FL
    201
    I'd suggest looking at Walmart, they typically have 10% liquid bleach on the shelf for $3.65, or a two pack for a little over $6. Confirm date on the package, you should see a 17 (the year) followed by three digits (number of day in the year it was produced), should be within 60-90 days. Clorox can do in a pinch, but liquid chlorine has a higher concentration.
    Free Form 13K IG (Quartz) w/Screen Enclosure - 2 Sheer Descents, 1 Bubbler - Hayward 60 SF DE Sta-Rite - Hayward SP3400VSP EcoStar - Hayward Aqua Rite AQR9 (T-Cell-9) SWG - Zodiac MX6 - July 2016 - Taylor K-2006 - Taylor K-1766 Salt Test
    Jul 2014
    Plainfield,NJ
    22
    Quote Originally Posted by bobandsherry View Post
    I saw a higher concentrated pool chlorine at lowes that was at 10% hypochlorite. its from Pool Essentals? Can I use this.Pool Chlorine4.jpg
    Jul 2017
    Throop, PA
    113
    I used that chlorine from Lowe's right before I decided to just drain and start over.
    One bottle was dark colored another was much less dark colored. It's a guess what I was getting.
    I believe in the value of a source with a big turnover.
    It's Sodium Hypochlorite you're looking for on the clorox or other bleach.
    The only way to advise you properly would be show us a picture of a label and we can tell you what it means.
    Yes, the junk behind the pool is a major issue. No CYA is tied for first place issue.
    Get anything out of the pool that you can. That way there's no mystery.
    Ellington, CT
    255
    Go to the Ocean State Job Lot in South Plainfield. They have 12.5% chlorine at $2.99 a gallon and its always fresh.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
  20. Back To Top    #20
    37,422
    How are you getting a FC of 2.3? That is not possible with the FAS-DPD chlorine test.
