BigGuy
0
Okay, so here's what I think:
Not the way I would do it, but here's a simple test for the skimmer: Put your garden hose into the skimmer line at the pump and see if water runs into the skimmer. It's higher than the skimmer, so you should see water inside the skimmer (if the line is open) before it overflows. This will tell you if the plug in the skimmer belongs there. If water does appear in the skimmer, you can take out the PVC plug and replace it with a rubber freeze out plug instead so your basket will fit. If NO water appears in the skimmer and the pump overflows, then the capped line in the skimmer goes to the pump - uncap it any try again.
As far as the return lines are concerned, here's the only (common sense) explanation I can figure. I would guess that the only return line is the one with the reduction fitting on it, either that, or the pipe may have been replummed and a tee added so that one fitting could be a return and the other an accessory. I'm willing to bet that the previous owner had an accessory installed at the reduction fitting, such as a fountain. The best way to tell would be as I described earlier, with the garden hose adapter from Home Depot:
This adapter expands to more than 1 1/2" and seals the pipe, forcing the water from the hose back through the pipe. If you do this, I would start at the capped (new) fitting and see if water comes out the smaller one, I think it might. If it does, plug it and see if you can reverse fill the filter. This is the best and quickest way to do it without a smoke generator. If the filter starts to reverse fill, you know you have the right return lines.
Now for the oval fitting? I have never seen an oval fitting... ever.
-Rich
-Rich
