I haven't added because I was contemplating converting. However, the process has taken longer and now I think it will be a spring issue. I was adding the dosages weekly until my conversion thoughts started.
In many ways I don’t blame you. The swim season is short enough as is up north and taking a few weeks to convert makes it even shorter. So let’s tackle your algae now using Baquacil and worry next Spring about converting.
The first thing you need to do ASAP is get some Oxidizer in the water. You’re very very close to a major algae outbreak. Vacuuming to waste is simply putting a mask on the main issue, algae is reproducing faster than you’re killing it. Soon your pool will be a nasty green if you don’t get aggressive in killing the algae. Your Sanitizer/Algaestat levels seem OK at 50ppm however with zero Oxidizer in the water there’s very little killing going on. Add the recommended dose of Oxidizer and brush.
