Thread: Stain? feels smoother than plaster?
    I am wondering about these marks on the pool. They are grey and feel smoother than the plaster itself. I sort of suspect that the Polaris, which was in need of new tires when we bought the house, may have been damaging the pool surface. I can try to take photos but I really don't know how to post them.
    I see that some of the neighbors have replastered... is that something that is done after 8 or 10 years normally? How do you know if it is necessary?
    Guest
    Re: Stain? feels smoother than plaster?
    Quote Originally Posted by anonapersona
    Yes, normal plaster maintenance is acid washing every 3-5 years and re-plastering every 10-15. Some aggregate surfaces might not need this as often if water balance is carefully maintained. If you do not maintain proper water balance the time frame could be significantly shorter! YMMV
