Thread: what levels FC are safe to swim in?
    Jul 2008
    West Point, VA
    29
    We shocked at night to clear up the pool, and FC levels are currently at 8.5. When is it safe to let my kids swim. They are eager to get in, and I'm eager to let them so they are occupied and happy.
    24' round AG vinyl liner
    200 lb/26" Baquapure sand filter with 2.5 HP pump
    converted to BBB end of 2008 season, and it's worth it!!
    jefeyessica's Avatar
    May 2009
    Dallas, TX
    62
    Re: what levels FC are safe to swim in?
    8.5 is fine. I read somewhere else that many public pools keep theirs at 10ppm
    14,200 gallon in ground Plaster Pool
    "Titan Vertical Grid Filter" -- Pressure DE, 60 sq ft filter area
    Mar 2008
    Roseville,Ca
    30
    I let my kids swim at that. After my last shock I let them in at 10FC and they are still alive and well
    10,500 gal Gunite,Imperial White River Rok,1.5hp Pentair Whisperflo,320sqft Clean & Clear,Intellichlor 40 SWG,EasyTouch w/Remote,Pentair Pool Shark Sweep(suction side),Jandy AE2000 Heat Pump & 8mil Solar Blanket,SAM Light,18in Caribean Shelf,6 & 4 ft Benches
    Safe FC levels depend on your CYA level. Personally, I consider anything from the minimum up to shock level for your current CYA level, see the Chlorine/CYA Chart, to be fine.
    Jul 2008
    West Point, VA
    29
    Thanks all! Per the chart, its definitely under shock level FC level but over over target FC.
