Thread: Use pool cleaner booster for fountain?
    Aug 2008
    League City (Houston), TX
    2
    I purchased a FlowerFall pool fountain a while back, but it only sprays up a foot or so unless I really increase the flowrate on my pump (even then it doesn't spray much higher).
    I finally got around to making an adapter so that I can plug the fountain into the wall fitting where my Phantom pool cleaner attaches. I tested it briefly and the fountain works great on that connection since it has a booster. My question is am I damaging my booster pump (or anything else) by doing this? The booster manual says never to run the booster unless the cleaner is attached.
    -Tim
    16,000 gal in ground pool/spa, DE filter, SunStone Select Cobalt Blue aggregate plaster
    IntelliFlo VF, IntelliChlor IC40, IntelliTouch i9+3, Mobile Touch, FNS Plus 48, MasterTemp 400NA, Whisper Flo WF24 (for water feature)
    Jul 2007
    Rockville, CA
    99
    Re: Use pool cleaner booster for fountain?
    If your pump isn't making that horrible sound it does when you run it without your pool cleaner, you are probably fine. I think it needs sufficient back pressure to avoid damage. What kind of height are you getting now?
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
    Aug 2008
    2
    It goes about 12 feet up with the booster pump on and actually looks like the fountain packaging advertises.
    There's a "bypass door" on the fountain to control how much water actually reaches the fountain head. I started with that fully open (no water reaching the fountain head) and the booster pump was making some loud noises. It was a lot better with the door closed, but I still don't think it was as quiet as when the cleaner is attached.
    I don't know if it will have any affect, but I'll try adjusting the filter pump speed (since I can't adjust anything on the booster) to see if having that high or low brings the booster pump noise down to the normal cleaner range.
    Tim
