Thread: granular CYA clarification
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    I would like to recommend that the pool school articles be updated re: granular CYA and the dissolving time. people are thinking that it's going to take a week to WORK as opposed to simply register on the test. so if it's true that it should be working right away (as soon as it's dissolved from the sock or however they do it) which is what I understand from what I've read here, I think the articles should be updated to reflect that so people don't go out and spend a lot of money on liquid conditioner because they need it "right away". here are two articles I know of.
    pool-school/pool_water_chemistry
    pool-school/recommended_pool_chemicals
    I've seen this come up a couple times recently, here is one example:
    new-test-kit-and-new-pool-t15144.html
    Re: granular CYA clarification
    Yes, I have been seeing that way too often recently. I just rewrote the CYA paragraphs in both of the articles you mentioned. Do the new versions seem any better?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    well it looks like you talk about the expense of liquid, but like the post mentioned above, she didn't care about the cost, she just needed it "right now". I don't see anything that reflects the granular taking effect as soon as it's dissolved (if it in fact does).
    Granular doesn't take effect instantly. It is at about 50% after 12 hour and 75% after 24 hours (those times can vary quite a bit). However, I really can't think of a situation where it taking that much time actually matters. The only disadvantage of the liquid product is the cost.
