Thread: Soft tap water caused some problems
    IkeRay's Avatar
    Houston, Tx
    154
    current test results:
    FC - 3.0ppm
    CC - 0.0ppm
    pH - 7.4
    TA - 200
    CH - 150
    CYA <30 but close to
    Well, I have some plaster to repair on the top step. should I drain down and use a normal repair kit or are the quickset just as good?
    secondly, because of the soft tap water and having replaced so much water and rain water having sat for too long in the pool, the CH was close to 50 for a good 3 months. I had my friend who has worked on pools for 14 years over last night and he told me it was definitely pitting caused by the low CH and that the only repair is full replaster. is this the case? there isn't much, its just a corner in the deep end, is there another solution?
    30,000gal In-ground Gunite Pool DE filter
    Polaris 380 APC
    BBB method all the way - Newb, like to absorb info and chatter, but take the experts' advise
    Re: Soft tap water caused some problems
    It is simpler to work above water. If you don't need to drain very much it is probably worth a partial drain. Still, working on small areas underwater isn't all that difficult, so don't drain too much if you don't have to.
    The only repair for pitting is a full re-plaster. But you don't have to do it right away. You can wait till the plaster gets much worse.
    IkeRay's Avatar
    Houston, Tx
    154
    Thanks jason, I'll put off the re-plaster, its just not in the budget and it may be unsightly, but its not doing any more harm so...and I'll probably just do an underwater repair, no need to drain and refill 5k gallons especially since we just got a water bill for 25k gallons since using power washer 2 weekends last month
    got in today and noticed the pitting is actually all around the pool, just worse in the deep end corner, but its not horrendous, I only noticed because I was up against the wall looking for it.
    Polaris 380 APC
