Results 1 to 11 of 11
Thread: Impact of salt on the screws inside pool posts?
    Hi everyone, my first post here
    I'm getting my first pool installed on Monday or Tuesday 8). So, as you can guess I don't know a lot about pools, I'm a real novice. However, I tried to do my homework as much as I could by reading (a lot) and talking to many people. I learned a lot already on this forum, so thanks a lot . By the way, I live in Canada.
    My case:
    I bought an above ground poll made by this company, it's the JAZZ model : http://www.aqualeader.com/swf/index.html
    This pool is completly made with resin, execept the screws and the walls. I also bought the SWG Aqua Trol from Golden Line (Hayward).
    My question about rust:
    I know the pool should not rust because it's all made of resin (execept the walls and screws). For the walls it's should be ok:
    - Steel wallsfinished with Duratex 2000 anticorrosion paint (seems good)
    - Internall walls protected against humidity and chemicals
    I'm more concern about the screws, that are inside the posts at the top and bottom. Are they going to rust because of the salt? Can they rust to the point that they could break and/or then make the pool not secure?
    Your opinion is welcome.
    BIC - the novice
    Don
    SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter
    Pentair Intelliflow pump
    Pentair SWG
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    Mar 2007
    Coastalish 'down easter'
    4,160
    BIC, congrats on the impending pool! As long as the screws are properly made stainless steel the 2700 - 3400 ppm salt won't harm them. However, last year there was a problem with Hayward light screws being improperly manufactured and rustinf out very quickly in salt pools If you notice any rusting of the screws, simply remove one and take it to a good hardware store and get stainless replacements - it shouldn't be expensive and is a quick and easy fix 8)
    Luv& Luk
    -Ted
    I was wondering if the water would get into the posts and then start rust on the screws inside the posts. There is few screws on top (inside) of each post and one at the bottom of each post.
    The pool manufature told me that the pool is guaratee for SWG, but with everything I read about rust and SWG, I'm not sure anymore.
    Don
    SW Florida
    Pentair SWG
    Is any member of the forum had any problem with their Pool screws getting rusty? I fthe answer is no, I guess I'm ok. Anyone?
    BIC 8)
    Don
    SW Florida
    Pentair SWG
    Shelley N's Avatar
    Denver, Colorado
    199
    BIC -
    I'm am waiting and watching as I would like to just add some salt to my water for comfort. I would love to think it won't hurt, but I'd be kidding myself if I thought I could keep the salted water off anything that was metal.
    Shelley
    Shelley
    Denver, CO
    Ft Lauderdale, Florida
    1,462
    BIC,
    I dont know what the screws are made of but if they are stainless steel, you shouldn't have any concerns. If they are not, perhaps you can request s/s screws, or replace them on your own, although I think there are alot of screws.
    Occasional rinsing of your pool, especially around the screws, should ensure better conditions to avoid any problems.
    Shelly, you should not have any problems if you're adding salt for the comfort, by adding enough to get to 1000 - 1500 ppm.
    Hope this helps,
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Quote Originally Posted by Poolsean
    BIC,
    Hope this helps,
    Hi Poolsean,
    As describe in my first post, the pool is completely made of resin except the screws inside the posts. So I cannot really rinse the screws as they are not visible (inside posts). I looked in the PDF manual (manufacture Web site) and the part that describes the pool parts says that thery are stainless screws. However, they do not specify what kind or grade.
    So what do you think?
    Quote Originally Posted by Shelley N
    BIC -
    Shelley
    Shelly,
    Other than the screws, is your pool made of resin or metal?
    BIC
    Don
    SW Florida
    Pentair SWG
    Shelley N's Avatar
    Denver, Colorado
    199
    Some of each. Aluminum rail, steel sides and buttress free uprights, along with screws to secure the side together and all manner of metals associated with a pump and filter that's located 5 ft away from the pool.
    Shelley
    Denver, CO
    1,462
    BIC,
    I wouldn't be too concerned.
    BIC,
    My concern is if the screws get rusty, on a long run can they break or make the pool not safe?
    Don
    SW Florida
    Pentair SWG
    1,462
    The remote possibility that enough screws would rust through to cause it to fall apart is far fetched and may occur long after you will have needed to replace the liner for whatever reason, NOT as a result of salt. If it makes you feel better, or for more peace of mind, spray the screws afterwards with Rustoleum.
