- Nov 20, 2013
- 2
Hi All,
I have a 10 year old pool which has a Whisperflo Pump, Newer Pentair Clean and Clear Filter, and a Ruud heater. Recently the pump began having a strange issue. It won't prime no matter how many times I fill the basket (I've done it till I raised the pool level to the top from filling it). I've checked for supply side leaks, replaced the pump basket lid, diffuser, and impeller so the pump is brand new inside. Interestingly if I pre-fill the filter by running the pump while filling with a garden hose until water spews from the air bleed, shut pump off until basket is over flowing, throw the lid on and it primes right up! No air in the basket and it'll stay primed till the next time it shuts off and I have to repeat the process. I am stumped as to what pre-filling the filter is doing and what I am missing here. Restriction on the return side? Hope someone can help as as this time I've removed the "on" tab from my timer so it doesn't sit and run dry but I have to re-prime it every day!
Thanks in advance for your ideas!
